Transfer Forward shifter to Top Shifter
Old Oct 12, 2009 | 01:39 AM
discostuee's Avatar
I have purchased a transfercase RF1A off ebay and finally got it to find its a front shift on it and the top is caped off.
Is it easy/ possible to use my shifter from the other case in my car (leaking like a sieve) to change without dismantling the whole thing?
cheers
Old Oct 12, 2009 | 06:32 AM
TORTIS's Avatar
I think the shift rods are different. call marlin.
Old Oct 12, 2009 | 06:50 AM
jimep's Avatar
Its been a year or 3 since I put dual cases in my truck and messed around with them but I know its possible to switch them out. I think U have to change the shift fork inside and one or both shift rods. Somebody correct me if I'm wrong please. Its realy easy to do and I think Marlincrawler has a detailed tech writeup on ripping apart and reassembling t-cases for the dual case setup. Useful info that will be more than enough to help u get the job done.
Old Oct 12, 2009 | 07:04 AM
waskillywabbit's Avatar
You are going to have to convert it over as the shift rails/forks are different. You can use your old tcase stuff to convert it.
Old Oct 12, 2009 | 08:06 AM
NYChopshop's Avatar
"The toughest part of a Jeep is the chick driving it."
... as in my girlfriend and her lifted XJ (to fit the same 31x10.5r15s I fit from the factory mind you) sitting dead in my driveway with a leaking rear main seal and funked charging system...
Wabfab... you're my hero.
Old Oct 12, 2009 | 08:13 AM
dropzone's Avatar
Fossilized
you can get a kit:
http://trail-gear.com/top-shift-conversion-kits.html
http://www.inchwormgear.com/store/index.php?cPath=21_64
Old Oct 12, 2009 | 12:08 PM
akaphilly's Avatar
i converted mine, its pretty easy and just takes some measurments.. this pic is for the high/low side only.
Old Oct 12, 2009 | 03:56 PM
jimep's Avatar
lmao. Iv'e owned multiple jeeps and must say i got a real kick out of this. Finaly saw the light and now own nothing but yotas. So true as 3/4 of jeeps around here are driven by females. Sorry to jack the tread.
Chumlee780
Nov 13, 2015 03:18 PM
Tonetrk
Aug 6, 2015 10:06 AM
Tonetrk
Aug 3, 2015 08:47 PM
Iceman4193
Jul 15, 2015 04:48 PM
crashburnoveride
Jul 10, 2015 06:39 AM
