Bolting exhaust manifold without stripping threads...
Old Oct 14, 2009 | 04:59 PM
rustypigeon's Avatar
Hey all. I have my freshly resurfaced exhaust manifold sitting on my workbench. I am going to put it on tommorow after a few gaskets arrive from the dealer.
While doing a search, I found that many guys are stripping the threads out of the head when tightening the nuts on the studs. I am now getting paranoid that this will happen to me when I try to bolt my manifold on.
What are some tips to avoid stripping the head threads?
I have ordered all new OEM nuts, I plan on reusing all the old studs exept the 3 that came out with the nuts.
Will I be OK if I thighten the nuts to the factory spec 33 ft/lbs? Or should I back off from this number a bit?
I don't want exhaust leaks, but at the same time I don't want stripped threads!
Old Oct 14, 2009 | 05:07 PM
Jay351's Avatar
Clean the threads on the studs, make sure there is not additional friction that might cause a stud to strip...
why didnt you buy a header?
Old Oct 14, 2009 | 05:10 PM
RustBucket's Avatar
Put a little anti-seize on the nut and torque it down. Recheck your torque after a few thermal cyclings.
Old Oct 14, 2009 | 05:16 PM
Will I be ok using 33 ft/lbs?
Blamalam
Mar 12, 2022 07:34 AM
tj884Rdlx
Aug 28, 2015 12:04 PM
upongame619
Aug 1, 2015 12:12 AM
Dakotaneu
Jul 27, 2015 12:03 AM
