Relocating Radio Antenna
Old Oct 8, 2009 | 09:15 AM
Monochrome's Avatar
I did a search but couldn't find something that was applicable enough. I've doing a ton of work on my truck (interior, exterior, maintenance, bodywork) on my truck and I'm going to be painting it with Interlux Brightside. I will definitely be making a build thread about this.
I don't like the location or looks of the antenna, so basically I want to mount it somewhere else, and cover up the hole of the existing location with fiberglass before I paint. I was thinking about laying it horizontally inside the passenger fender panel (next to the battery). I think if I do this the only downside will be reduced AM reception, but FM will be largely unaffected. I also have a Zune with FM reception that works great either way.
Any thoughts, or people who have tried this themselves?
Old Oct 8, 2009 | 09:55 AM
poynter's Avatar
A lot of compact cars have them in the a-pillar. I think that would get better reception than under the hood but maybe not... When i had a car that had the a-pillar antenna I always had it crammed down in the hole and it still worked fine... maybe you could snag that part at a junk yard.
Old Oct 8, 2009 | 10:58 AM
scaesare's Avatar
You could try what I did with a HAM radio antenna HERE with an aftermarket AM/FM antenna, if the goal is to just get it off the sheetmetal.
That's not an "invisible" install tho.
-sc
Old Oct 8, 2009 | 12:31 PM
Monochrome's Avatar
poynter, good idea. I'll see if that's possible.
scaesare, great writeup, and the final product looks awesome. I do think I want mine to be invisible though. I used to have a huge CB antenna and other stuff on my truck, but I'm looking for a really clean look now.
I'll take pictures of whatever I end up doing.
Old Oct 8, 2009 | 12:56 PM
Etype R's Avatar
Most aftermarket replacement fenders do not have the antenna hole, I would just buy a new fender if you are repainting the entire truck. Less body work to mess with in the end
Certifit panels for the 89-95 trucks were around $26 when I checked pricing last month.
Old Oct 8, 2009 | 01:02 PM
Monochrome's Avatar
That's a great idea, but I already sanded it down, little bit of bondo, and it's prepped for paint aside from a the potential radio antenna hole. That and I'm probably painting on Saturday...
kawazx636
Oct 6, 2021 03:03 PM
mct75
Aug 22, 2016 01:24 PM
zombie_barbarossa
Oct 2, 2015 10:54 PM
tazman1972
11
Sep 28, 2015 10:32 PM
Ilovemountains
Sep 15, 2015 04:17 AM
