engine painting questions
Old Oct 16, 2009 | 05:10 AM
xxxtreme22r's Avatar
1: strip and paint the harmonic balancer
2: strip and paint the other pullies
3: reuse the crankshaft keys (how the heck do they come out anyway?)
4: strip and paint the fan clutch
5: paint the fan
6: paint the radiator
might add more as time goes on.
thanks.
Old Oct 16, 2009 | 05:28 AM
James Dean's Avatar
Main thing with balancers is to be careful if it's a two-piece that has rubber, strippers can hurt it. Second thing is to make sure that if you paint anything that spins, that it has as even of coats as you can humanly get. Little thing called balance.
It's not recommended to paint radiator cores because it can reduce the heat transfer ability. But you can paint the tanks.
Old Oct 16, 2009 | 05:31 AM
just working on a rebuild of the 22r
Old Oct 16, 2009 | 03:02 PM
yoterr's Avatar
you can paint the pullys....but there gonna end up black in the middle anyways? or r u just going for the outside? and yeah you can paint the fan mine is....but its coming off
Old Oct 16, 2009 | 03:39 PM
painting all pulleys black, don't want to get new ones and they need "freshening up"
Old Oct 16, 2009 | 03:52 PM
iamsuperbleeder's Avatar
I don't see a big need to strip them, just clean them up really good, and run over them with a red scotch-brite pad. then just hit 'em with some paint
that's all I did, and it came out fine
but yeah, I wouldn't reccomend painting the radiator
Old Oct 16, 2009 | 05:24 PM
bleeder: did you also paint the grooves in those or tape them off?
Old Oct 16, 2009 | 05:30 PM
I didn't worry too much about them. A little over spray got in them, but it's not like it matters, cause the belt is going to rub the paint off the inside of the groves anyhow no matter HOW MUCH you prep the surface, of WHAT paint you use
Old Oct 17, 2009 | 01:43 AM
thats what i figured. thanks. so pulleys definitely, haven't made up my mind about the fan blade yet. radiator is out unless i can find the eastwood paint outside of being online:
http://www.eastwood.com/eastwood-rad...ack-paint.html
http://www.eastwood.com/ew-radiator-...in-finish.html
Still not sure on if i should paint the fan clutch or not.
Balancer I guess I can paint.
Putting a new crank in and I am not sure if i should get new keys or not, but having difficult time getting the ones out of the old crank.
Old Oct 17, 2009 | 02:41 AM
92 TOY's Avatar
I'm assuming we aretalking about the 22r engine you have listed in your sig. Plastic fan, right???
Soak it, clean it, de-skank it. Plasic primer and then the color of your choice.
On my 22re I haven't gotten THAT far yet , but when I replaced the radiator and hoses on my son's '88 4runner 3vze, we did paint the fan......prepped just like I said and then we found a can of paint intended for chrome (it's transparent paint), red, and when we did it up it came out looking like a piece of candy. Like a cherry cough-drop. Looks good enough to eat.
From this........
[IMG][/IMG]
To this.........
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
And if your question was to "paint" the radiator?? I never would. Just spend the $100 and get a new radiator....was the best money I've spent so far and probably the easiest repair I've done too.
My son's radiator, old and new.....
[IMG][/IMG]
and mine.........
[IMG][/IMG]
A new radiator adds peace of mind, whether or not you really needed one, but after years of service, invariably, something will be wrong with it, so just do it.
And a red fan adds 15 horsepower....LOL.
Old Oct 17, 2009 | 02:50 AM
92 TOY's Avatar
Oh yeah, P.S.
The radiators are SPECTRAs from JcWhitney.
IAMSUPERBLEDER has the same one.
Old Oct 17, 2009 | 05:17 AM
James Dean's Avatar
I thought yellow added HP. I guess I'm covered cause I have both colors. No wonder it's so fast.
Old Oct 17, 2009 | 05:20 AM
92 TOY's Avatar
James, that's just plain nuts!!
And I love it!!!
Old Oct 17, 2009 | 03:45 PM
ACTUALLY, my Spectra radiator came from Advance Auto Parts, for right at $100
and I also didn't have to worry about painting my fan and clutch, cause well, I did away with it
bigjstang
Jun 2, 2025 03:56 PM
kazuya2416
Apr 5, 2024 02:17 AM
icentropy
Sep 16, 2020 02:47 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
