best header & air filter set up for 93 22re
Old Oct 9, 2009 | 04:52 PM
robert1965's Avatar
I am looking for the best header, and cold air system etc. thanks
Old Oct 9, 2009 | 06:39 PM
kawasakimoto_7's Avatar
.. i guess this could fall under all about you prefrence and what you can spend. but for header i would go with doug thorley, and for intake just put on a K&N open cone filter on the end of your intake tube.
Old Oct 9, 2009 | 07:01 PM
Junkers88's Avatar
"Best" is an open question. Best header is a DT, best intake is a Supra VMAF/battery swap and Spectre contained cone with a snorkle feeding it........... in my opinion.
If you run street punch the intake through the valance to get good forced clean/cool air. If you run rocks cut through the hood for slow movement air. If you run mud/water run a snorkle or pull from the cab through the firewall.
Old Oct 9, 2009 | 07:31 PM
olharleyman's Avatar
Very close to my set up no snorkle YET but the supra afm (Thanks Junkers) with the L.C. Engineering Pro Street head (I am sure engnbldrs Pro Street head would be just as nice and it and it's $500 cheaper) engnbldrs 268 cam makes a very nice set up I just did the valve re-adjustment after the first 350 miles on rebuild and what a difference it is not a v8 but for a 4 banger it out runs/pulls my 90 4runner 3.0 both on 35's with 5.29's.
Old Oct 9, 2009 | 07:44 PM
BigBluePile's Avatar
You could always search and see what others have done...
smthwsn357
May 1, 2024 07:28 AM
Eggslinger
Jun 8, 2019 03:32 PM
Sep 4, 2015 09:27 AM
88runnergomas
Jul 9, 2015 01:12 PM
skoti89
Jul 8, 2015 12:05 AM
