lift on 94 pu 2wd
Old Oct 13, 2009 | 07:11 PM
rafale01010's Avatar
Question lift on 94 pu 2wd
What would be an easy way to lift up my truck 2-3in if possible without puttin too much money in it? I would like to be able to put 31s, so i need to lift it up at least 2in, on it but with some 235/75r15s i had were scrubbin fairly bad in the front so i switched those out with street tires to stop the scrubbing.
Old Oct 13, 2009 | 07:58 PM
rhill's Avatar
check these out first:
https://www.yotatech.com/forums/f116...thread-183959/
https://www.yotatech.com/forums/f116...pickup-189380/
https://www.yotatech.com/forums/f116...pindle-193416/
you can find more stuff using the search option.
Old Oct 13, 2009 | 08:08 PM
Built2Grind's Avatar
lift spindles, bj spacers, and relax your torsion bars about an inch or 2...you will be happy
Old Oct 14, 2009 | 05:39 AM
Robert m's Avatar
31's are not going to fit with only 2'' of lift
Old Oct 14, 2009 | 07:29 AM
Junkers88's Avatar
Yes they will. In fact they will fit with no lift at all.
edit: I just realized we were talking about a 2 wheel drive rig. Forget everything I said, I'm a ding bat.
Old Oct 14, 2009 | 07:47 AM
If i did try too put them on there, the back would just fit but front would be scrubbin like hell, worse than the 28s i had did. The main problem with that is that im prolly overdue on getting new shocks and leaf springs, as they are almost completely level not bowed like they should be.
Old Oct 14, 2009 | 07:58 AM
91Toyota's Avatar
True, they "might" fit with no lift at all. But after the tire hits your fender you wont have a tire or a fender left.
Do you have a pic?
And no offense, but why would you want to life your 2wd??? For what purpose?
Sep 4, 2015 09:27 AM
Ernie217
Aug 14, 2015 05:25 AM
Pedalpwr27
Aug 13, 2015 06:37 AM
coffey50
Jul 28, 2015 10:55 AM
colasurdo
Jul 16, 2015 11:32 AM
