lift on 94 pu 2wd
What would be an easy way to lift up my truck 2-3in if possible without puttin too much money in it? I would like to be able to put 31s, so i need to lift it up at least 2in, on it but with some 235/75r15s i had were scrubbin fairly bad in the front so i switched those out with street tires to stop the scrubbing.
check these out first:
https://www.yotatech.com/forums/f116...thread-183959/ https://www.yotatech.com/forums/f116...pickup-189380/ https://www.yotatech.com/forums/f116...pindle-193416/ you can find more stuff using the search option. |
lift spindles, bj spacers, and relax your torsion bars about an inch or 2...you will be happy
31's are not going to fit with only 2'' of lift
Originally Posted by Robert m
(Post 51252425)
edit: I just realized we were talking about a 2 wheel drive rig. Forget everything I said, I'm a ding bat. |
If i did try too put them on there, the back would just fit but front would be scrubbin like hell, worse than the 28s i had did. The main problem with that is that im prolly overdue on getting new shocks and leaf springs, as they are almost completely level not bowed like they should be.
Originally Posted by Junkers88
(Post 51252467)
Yes they will. In fact they will fit with no lift at all.
Do you have a pic? And no offense, but why would you want to life your 2wd??? For what purpose? |
