86 4runner engine swap question
Old Oct 15, 2009 | 03:11 PM
ethanp123's Avatar
im thinking about buying an 86 4runner with a 22re turbo efi motor. the motor is bad and needs replacement. I have a 1993 toyota pickup with a 22re efi non turbo wondering if i could swap them out? also keep the turbo or stay with the intake on the 22re efi non turbo? also keep in mind these are a few years apart so main question is will this motor work? and could i use that turbo intake on it?
Old Oct 15, 2009 | 03:55 PM
75k5toy's Avatar
I just don't get it, why do you want to dig a hole to cover another one? if you like the runner buy it n fix it, there's nothing nicer than a good running turbo toy. And keep your truck running, you can sell it whenever you need the $$$$$
Old Oct 15, 2009 | 04:03 PM
ethanp123's Avatar
the thing is the i live in maine and frames dont last long with the they put on the road in the winter. so my pickup has holes in the frame and the 4runner has a mint frame.
Old Oct 15, 2009 | 05:16 PM
ethanp123's Avatar
so i need to know if the normal non turbo 22re will work?
Old Oct 15, 2009 | 07:19 PM
toyminator2000's Avatar
The turbo motors have lower compression to handle to boost.
Old Oct 16, 2009 | 03:25 AM
ethanp123's Avatar
so maybe get rid of the turbo, and put non turbo 22re motor in. that will work right?
Old Oct 16, 2009 | 03:45 AM
jimep's Avatar
I'd throw turbo (deep dish) pistons in the re block, drill and tap the block for the turbo oil line behind the oil filter, run the turbo oil drain into the oil pan, and wire it up using the 86 turbo 4runner harness and sensors with the 93 intake manifold. run 93 octane to avoid detonation since it will have higher compression w/ the re head. Thats similar to what I did and I'm still pushing 10 lbs of boost.
Old Oct 16, 2009 | 05:50 AM
ethanp123's Avatar
ya thats quite a bit of work. i think i might just put my 93 22re in and run it. it wont have as much sake but be a little easier to instale.
Old Oct 16, 2009 | 09:19 AM
75k5toy's Avatar
Well, the good part is you have both trucks to work with, cause I think you need to swap other parts besides the motor, There's another place around, that relates to turbo trucks only, you may get more info there. good luck.
GreenLion
Jun 7, 2021 10:49 AM
Goddamnboh
3.4 Swaps
12
May 11, 2016 09:22 PM
noahstancik
Jul 10, 2015 11:18 AM
Alex Bessinger
Jun 28, 2015 10:05 AM
TheManOutside
Jun 18, 2015 03:32 PM
