power stearing fluid leak
Old Sep 8, 2007 | 03:36 PM
Trons's Avatar
my friend has a '93 runner that's leaking a quart of PS fluid every other day...the problem is that there is no visible evidence. We've had my mechanic look at it (for almost 3hrs) and he couldn't find it. he put it on his lift, ran tests with it running and such and no luck.
My '84 yota has a simple PS system, but this '93 is much different. From what I've read, it shares some areas with the brake system (but the fluid isn't leaking into the brake system because the brake system shows no change in fluid level).
Any help on this would be greatly appreciated.
Old Sep 8, 2007 | 04:13 PM
86tuning's Avatar
check the vacuum hoses running from the idle up pressure switch on your p/s pump. If there's fluid inside there, replace the pressure switch and the vacuum hoses.
HTH.
Old Sep 8, 2007 | 06:12 PM
Trons's Avatar
K, I can check that, where would the fluid be going? there is no sign of it on the pavement and it leaks whether it's running or not...my friend has parked it for a couple days and it still leaked...no visible dripping anywhere...driving us crazy.
Old Sep 8, 2007 | 08:29 PM
Itoyota's Avatar
Ive had a long list of problems with my PS on my 90 toyota pickup. It's got a steering gearbox (which has recently begun to leak) power steering pump, and vacuum lines to the IM. If there is no evidence of a leak that large. Then it as to be getting burned up (ie IM vacuum lines as 86 tuning has already pointed out) Good luck.
Old Sep 9, 2007 | 04:30 AM
Trons's Avatar
Oh...ok, thanks. I'll check that today. You guys have been a great help.
jasonty
41
Dec 23, 2018 01:00 PM
tj884Rdlx
Aug 28, 2015 12:04 PM
the1998sr5
Jul 16, 2015 06:20 AM
Rkellerman
Jul 12, 2015 08:42 AM
cars-guy
Jul 11, 2015 07:51 PM
