Finally Lockers
Old Sep 12, 2007 | 06:02 AM
onefast66nova's Avatar
Finally Lockers
After about two weeks I have new lockers front and rear!!! I orignally just wanted to change out my CV shafts but when I found out the grinding was not because of lack of grease and CV boots, i dug a little deeper. I found about half the teeth on my front ring gear was missing..... Strange how that makes a funny noise in 4wd!! That is why I opted to go with a front locker. Now the rear I needed a pinion seal so the rear was gonna be out anyways!! right?? he he.. So far I love them (Aussie) Wonderful ppl to deal with!In the past 2 weeks I have had the front diff out of two other truck and out of mine 3 times......I am getting kinda good at it! Bill
Old Sep 12, 2007 | 06:21 AM
Taco Eater's Avatar
Please tell me your truck is yellow.
Old Sep 12, 2007 | 07:59 AM
tc's Avatar
tc
So, have you had it offroad yet?
What do you think about how it drives?
Old Sep 12, 2007 | 09:27 AM
Jay351's Avatar
How are they on the street? I assume since you have a rear aussie you have a 4cyl?
Old Sep 12, 2007 | 01:10 PM
TORTIS's Avatar
dude, no pics of the install, no write up are they as easy to put in as aussie makes it out to be? for sure my next major upgrade.
Old Sep 12, 2007 | 01:19 PM
olharleyman's Avatar
Yes they are I did my front but in the directions where it says to use grease to hold them together (Just trust me on this one skip the greese) it held mine together alright but did not let go either, so it was tear down and see what was going on then back together and same thing finally got hold of Aussie people and was told to skip the greese because it seems it don't want to let the parts that need to release to release but WOW what a differance it makes climing a hill or shoot'in thru some mud just got to get use to the new turning radius.
Old Sep 12, 2007 | 05:28 PM
Well this thing drives like a totally different truck!!! I have not had it totally off road yet but did go to a construction site late last night after I got it all done. All I have to say is when you can climb a hill that your front bumper scrapes going up with 1.5" BJ spacers, T.B cranked, and 34's Like your pulling forward at the drive through is verry impressive!!! On road with hubs unlocked an 2wd it drives almost like the same truck. If I throttle through a corner with a lot of pressure on the go stick the inside tire will chirp a lot, but if I coast or go slow no different. As far as install goes, not that bad, Just make sure you mark everything and keep everything clean. Would deffantly do again. What little mud I went through (dragging the new purdy diff through the center) the tires didn't even spin. I can wait to do some hills!!! BTW the truck is urtlra flat olive drab and flat black center of hood. Me and my buddies just paint random stuff on each others wheelin rigs. My color just happens to be yellow. It matches my 07 FJ Bill
Old Sep 12, 2007 | 05:36 PM
sdstud212001's Avatar
That yellow makes everyting else look filthy
Old Sep 13, 2007 | 05:12 AM
Well hopefully it will all be covered here in a week or so!! Mud will make everything look the same
Old Sep 13, 2007 | 06:35 AM
ZUK's Avatar
ZUK
No clunking sounds?....you must have an auto tranny
Old Sep 13, 2007 | 08:46 AM
No it is a 5-speed. There is slight clicking sound from the rear if you listen for it but I never hear it. The tires are so noisy that might be covering it up more im not sure....
justdifferentials
Just Differentials
Jun 13, 2022 07:40 PM
1uzRunner
63
Nov 10, 2018 03:58 PM
justdifferentials
14
Jun 11, 2017 08:36 PM
Patrick1976
Sep 15, 2015 11:33 PM
zz_denis
Sep 6, 2015 03:43 PM
