climate control light
Old Sep 16, 2007 | 06:49 PM
nix4x4's Avatar
The illumination behind my climate controls in my dash went out today. Just wondering how hard it is to install the light(s). Pretty clueless on this one so any help is appreciated
Old Sep 16, 2007 | 07:31 PM
toy power's Avatar
pull off the knobs, then pull off the face starting at the passenger side. the bulb is small and can be pulled right out.
Old Sep 16, 2007 | 07:37 PM
Jay351's Avatar
Very easy to get to the bulb.
remove dial knobs
pry off the little faceplate, I used my truck key
It will take out your AC switch (if you have it)
Then take off the little peice that spreads the light
Take off the bulb condom
and take out the bulb.
Old Sep 16, 2007 | 08:14 PM
algranger's Avatar
you could also pick up a nice bulb at superbrightleds.com theyre great!
Old Sep 16, 2007 | 08:17 PM
nix4x4's Avatar
yeah i was kinda thinkin about changin the bulb color or somethin just for little extra touch. Does the bulb make it that color or is it the tint of the plastic on the faceplate
Jay351's Avatar
Pretty sure its the bulb.
Old Sep 16, 2007 | 08:20 PM
Godzilla's Avatar
it can be the faceplate and sometimes the little jimmy condom adds to the colour emitted. check when pulling the bulb as some are those ones with the base that you need to turn. not sure how its set up for the 92, but just as a word of caution.
Old Sep 16, 2007 | 08:32 PM
algranger's Avatar
there is a little rubber... condom kinda thing on mine that filters out all but green light. you can order led's in pretty much any color
Old Sep 16, 2007 | 10:10 PM
Asha'man's Avatar
Mine's been out since I've owned the truck, so this is good advice. I have the HVAC panel memorized by touch, but I might still toss a bulb in there.
Old Sep 18, 2007 | 04:43 PM
shaeff's Avatar
led's FTW:
the pics do it no justice- it's actually BLOOD red. nice, dark red.
-shaeff
Old Sep 20, 2007 | 02:06 PM
algranger's Avatar
here is my blue LED dome light, just like above the pics don't do it justice it lights up the whole cab blue and it looks REALLY cool.
Old Sep 20, 2007 | 08:54 PM
nix4x4's Avatar
Shaeff, how much of a project was it to do all of that? My truck is black but I've been kinda keepin an inconspicious red theme goin, too (hubs, shock boots, decals, etc.) All red for the most part. I think that changing all of the interior lights from that ugly dim green to red. What kind of work was involved?
Old Sep 21, 2007 | 10:11 PM
nix4x4's Avatar
Also along these same lines, tonight I noticed something wierd. I shut off my truck with the lights still on, and when I did that the audio control lighting all went out, except for the volume knob light. When I put the key back in the 'ON' position (I didn't actuallt start the truck) the lights came back on. So, with the exception of the volume knob, the audio lights only illuminate with the ignition in that position. Once I turned off the lights, they all did go off like they should. Any rhyme or reason behind this?
Old Sep 24, 2007 | 03:37 PM
shaeff's Avatar
it's really not difficult to do. it's as easy as pulling the cluster. the led's i got were from www.superbrightleds.com. they're the 5angle pieces.
-shaeff
Charecter1
Nov 6, 2023 10:08 AM
AkitaDog
Sep 1, 2015 08:05 AM
kirkrunner
Jul 27, 2015 07:59 PM
rushw
Jul 18, 2015 01:46 PM
daddio
Jul 18, 2015 10:20 AM
