Help Its Too Hot In Here!!
Old Sep 11, 2007 | 06:15 PM
algranger's Avatar
hey guys,
i got a problem. when i drive i get a draft that comes through my heat/cooling vents which i think is normal? what i dont think is normal is that the air is really hot... way hotter than it is outside, and when it's 105 outside... IT SUCKS!! i think it might be the little valve that lets hot coolant through the firewall and back out and maybe it's leaking but thats about all i know. could i just disconnect the hose where the coolant goes through the firewall and connect it where it comes back out so it circulates outside the cab? can anyone help cause this really sucks. thanks a lot
Old Sep 11, 2007 | 06:18 PM
881stGenRunner's Avatar
change the selector from outside air to recirculation of air and keep the fan on OFF
Old Sep 11, 2007 | 06:20 PM
algranger's Avatar
i did that, i closed it all the way and it helped but still hot air
Old Sep 11, 2007 | 06:25 PM
hmm, close the vents that you can (driver side and pass side) then aim the two mid ones somewhere else. Then the little one below the steering column just aim down. You may have some kind of leak. I honestly dont know. Hopefully someone with more knowledge will chime in
Old Sep 11, 2007 | 06:49 PM
algranger's Avatar
thanks, im thinkin maybe the valve that cuts off coolant is worn out and leaking, would it hurt to disconnect the hose and stop flow completely?
Old Sep 11, 2007 | 07:02 PM
KevinInSac's Avatar
Good it just be heat from the floor boards and the natural circulation of air blowing it around?
Old Sep 11, 2007 | 07:34 PM
Shoua's Avatar
Ha ha, funny. I have about a 1/4" hole around where my steering shaft comes inside the truck. Hot and cold air enter through there. I went mudding yesterday and mud got on my feet! Good thing I was wearing sandals...
Old Sep 11, 2007 | 07:45 PM
longhungsilver's Avatar
If u disconnect the hose and reconnect it all under the hood u will be bypassing the heater core and u will have no heat in your car when you need it... Im not sure about your valve leaking idea doesnt sound right to me....
Old Sep 11, 2007 | 11:01 PM
toyotatom93's Avatar
I had a similar problem. It was caused by the heater cable being stuck open because a part of the cable would get snagged on the rim of the hole where it enters the center console. Now if I turn the heat on and ever want it off completly again I have to help the cable get thru that hole.
To find the heater cable just wiggle the controller and feel for a moving wire on the passenger side floor by the console, see if you have to help it get in.
Hope that helps
Old Sep 11, 2007 | 11:29 PM
ozziesironmanoffroad's Avatar
ok heres a temp fix if your engien is set up like mine. see in the middle of the firewall, theres the coolant hoses and the brake/clutch lines. there should be a little switch, or lever. pull that lever. that blocks any air from going to your heater. my heater didnt ever work until my buddy turned that lever. then it started workin great. so try that until you can get it looked at.
Old Sep 12, 2007 | 09:38 AM
Jay351's Avatar
set your air selector to cold. I get air comming in when my heater is off.
Old Sep 12, 2007 | 12:52 PM
algranger's Avatar
ya, but i wanted to do that until it gets cold and then hook it back up.. would it hurt aything to do that?
Old Sep 12, 2007 | 04:20 PM
86toysr5's Avatar
atleast u got heat my heat dont work for some reason
Old Sep 12, 2007 | 04:28 PM
check the heater valve switch under the hood, thats why mine wasnt working
Old Sep 12, 2007 | 08:14 PM
86toysr5's Avatar
yep it opens n closes....new tstat....heat core dont leak...i wanna try to flush.....
sorry for hijack
Old Sep 12, 2007 | 08:30 PM
no it wouldnt hurt a thing.. try it out and see if your heat lessens... im sure it will solve the problem but once u rehook it up (when it gets cold) your problem will be back again.. im really unsure of what is causign it. i hope someone will chime in...
but no it wont hurt to disconnect and bypass your heater core
Old Sep 13, 2007 | 01:30 PM
algranger's Avatar
it wont be much of a problem when its cold here cause when it's cold, its COLD! thanks
dbollier123
Sep 29, 2015 05:23 PM
Matthew Perez
Sep 28, 2015 05:43 PM
taraf
Sep 25, 2015 02:57 PM
LotOMiles
Sep 14, 2015 11:45 PM
anndel
Sep 10, 2015 08:50 AM
