scary underside is this bad??
Old Sep 7, 2007 | 12:26 PM
infiltrator's Avatar
okay, so i go to wash my truck this morning and go to see how big the nuts are to take off my damn runningboards...
i look up and see this!!! yikes!
is this okay? normal?
Old Sep 7, 2007 | 12:28 PM
04 Rocko Taco's Avatar
Do you mean the thin sheen of oil on everything?
While not out of the ordinary, its not a GOOD thing, but usually no cause for panic either, keep an eye on it, and keep it clean, that way you can tell if the leak ever gets worse, and when it is time to fix it...a lot of guys would say fix it now....but hey...if you can live with it for now...it looks good from my house.
Old Sep 7, 2007 | 12:33 PM
KevinInSac's Avatar
Common, I'd say if you're not dripping, then you are fine. If you feel so inclined, clean all of the grime off and see how it looks a bit later. Chances are the grime that is on there is many years in the making.
Old Sep 7, 2007 | 12:36 PM
alright ill get some degreaser and kill a towel and clean that all off lol. ill post a pic of it clean lol!!!
Old Sep 7, 2007 | 01:00 PM
fastkevman's Avatar
DON'T CLEAN IT!
Pray that it gets worse, can't rust bad with nice coat of oil!!!
HAHAHA
Old Sep 7, 2007 | 01:23 PM
rdlsz24's Avatar
Mine looks the same... as long as it doesn't drip I don't mind. I figure after 20 years it's probably a little tired lol.
Rob
Old Sep 7, 2007 | 01:27 PM
KevinInSac's Avatar
Originally Posted by fastkevman
DON'T CLEAN IT!
HAHAHA
Us California boys don't have to worry about that too much...
Old Sep 7, 2007 | 02:18 PM
<CA lol!! i hate the smogging out here i wanna do that isr mod soooo bad.
Old Sep 7, 2007 | 02:53 PM
KevinInSac's Avatar
And I want the Aux Downey Tank. I think I'll do it eventually, and just un hook it when it comes to smog time.
Old Sep 7, 2007 | 03:17 PM
fake smogs ftw!
Old Sep 7, 2007 | 08:01 PM
Tacoma750's Avatar
It should help prevent rust.....
Old Sep 7, 2007 | 08:03 PM
bob200587's Avatar
Have I ever seen a car that didn't look like that? Nope....not unless it's basically new.
Old Sep 7, 2007 | 08:21 PM
Four Runner's Avatar
Banned for being an asshat
Talking
Infiltrator...treat it like a small cut, just rub some dirt in it.
Dude, you're the victim of an automatic transmission, probably a 2wd version, right, that's been probably used to haul alot of stuff, and had some atf blow past the input shaft seal. That, and a bit of blowby oil from the rear of the valve covers.
Go ahead and clean it all down, it should be fine, you'll still get a few drops of atf from the vent (silver bellhousing cover vent) for a bit, but if you take it a bit easier, it should subside. If it is a continuous issue, as in it's already happened a lot before, and has affected the seal to the point where more than, say 5 or 6 drips a week, where you're able to verify fluid loss, as in check the transmission dipstick, get the seal replaced. Dealership or Transmission shop cost w/ the part was around $286 for a friends rig. also make sure if the transmission's ever serviced and the pan gets pulled that there's actually FIPG used, rather than a short-cutted use of a cork style gasket, that in time will leak. *The FIPG is a more involved process that takes an extra day for the material to cure, but is per O/E spec, and will rarely leak anything if done correctly.
Old Sep 7, 2007 | 08:24 PM
Lightbulb
That, or a Toyota that's been never wheeled.
All their transmissions leak at some point, just depends on how much.
Somebody needs to post a pic of their R-150 after a hard weekend..
Old Sep 7, 2007 | 10:45 PM
will do four, i will clean it and show my great cleaning skills, then ill monitor it. yes, you read my mind, i unfortunately have the 2wd... im not the big offroader, i use it for trips and stuff, and when we bought it were were tight on cash (my dad bought it what 13 years ago? hahahahah) now hes got a new 40,000 acura lmao!
i got the runner, and im not the best tech guy ever, and i tell you every time i come on here, i learn something cool.. i love it.
got another question...
okay so im going to do seafoam.
im putting it in all 3 places pcv valve, crankcase, and in tank...
when i change the oil, im doing synthetic...
should i buy like 2 quarts more of synthetic to add, when leakage happens?
another thing which SUCKS, my oil gauge is broken, the thing i think broke off lonnngggg time ago.. someone said it would cost 30 bucks to fix, but i was gay and said "oh ill dip the stick in every week" and never do it lol...
Old Sep 8, 2007 | 04:08 PM
Bumpin' Yota's Avatar
DON'T CLEAN IT!
HAHAHA
You actually have a VERY good point. Mine's been leaking for a long long long time.....not a single bolt in my engine compartment is rusted/stuck. Instead they are just entombed in oily dirt.
Old Sep 8, 2007 | 11:42 PM
i have this stuff grease lightning im going to use, im singing the song in my head lol.
ghostmoney
Jan 28, 2018 11:42 AM
Blamalam
Aug 16, 2015 12:29 PM
corey519
Aug 12, 2015 11:12 AM
nonstop
7
Aug 11, 2015 09:26 AM
keithporter83
Jul 18, 2015 12:37 PM
