3vze first timer
Old Aug 23, 2009 | 09:37 PM
royoder's Avatar
3vze first timer
I just replaced a timing belt on a friends 94 4runner 3vze. Its my first time ever even touching a 3vze. so i buttoned everything back up, and now it runs like crap. it will idle, very poorly though. it produceds alot of black smoke. alomst raw gas smell. it'll burn your eyes. if i didnt know better id swear ive got the spark plug wires all crossed up. but they are where they are supposed to be. im not an expert by anymeans but this aint my 22r. ive never had any difficulties working on it. where should i start? thanks.
Old Aug 23, 2009 | 10:06 PM
Jay351's Avatar
Are you sure you didnt get one of the cams off a tooth?
Did you time it?
Old Aug 24, 2009 | 12:23 AM
Nashman00's Avatar
to run like that you have bad timing belt timing cause there is no reason to pull the distributor
Old Aug 24, 2009 | 03:57 AM
royoder's Avatar
As much as i hate to im gonna pull the front back off and give it a check. I was so sure i lined the timing marks on the belt and everything. oh well
Old Aug 24, 2009 | 09:58 AM
Nashman00's Avatar
yea it is gay when you have to back track what yea did
maybe you got the lower pulley off by tooth that is what i am thinking cause the timing to be way off
easy way to find this out is Peace of wire and top dead center tdc and the piston still has some movement you off by 1 tooth on the lower cog or some thing
MadMax48
Mar 3, 2020 10:33 AM
Kamaloha
Oct 16, 2015 05:13 PM
alexcarey
Oct 14, 2015 06:05 PM
Matthew Perez
Sep 28, 2015 05:43 PM
