cyl 3 not firing
Old 08-29-2009, 11:08 AM
yoterr's Avatar
cyl 3 not firing
allright so ive got spark and the motors runnin pretty good except cyl 3 isnt firing, i unplug the plug wire and it arcs to the head so its getting spark, i think it might be timing related, if i goose the throttle it blows fuel back threw the carb so im guessing the intake valve is still partially open on the up stroke, you think i should jump the cam a tooth on the chain? and if the valves open on the intake wich way should i jump it? also the dist is all the way advanced it wont run in the middle (or run as it is in the middle) thanks guys
Old 08-29-2009, 12:44 PM
yoterr's Avatar
well figured it out, one of my rockers were way out of spec, got them all within specs (they were all off a little bit) and she runs like a champ thanks alot guys for bareing with me threw all the dumb questions
ladybugRC
458
08-21-2020 10:41 AM
Alexdosdall
12-10-2017 05:48 PM
smilen724
13
11-08-2015 04:11 PM
alexcarey
10-14-2015 06:05 PM
bradahman
10-01-2015 09:24 AM
Quick Reply: cyl 3 not firing
