LCE master rebuild kit
Old Aug 31, 2009 | 07:32 PM
sas'd22re's Avatar
anyone have any first hand experience with this kit? likes or dis-likes? thinking of building up my spare motor and want to go with quality parts
Old Aug 31, 2009 | 07:46 PM
olharleyman's Avatar
You should look into ENGNBLDR.com
Old Aug 31, 2009 | 08:30 PM
sas'd22re's Avatar
i have looked at engnblrd's kits and am going to go with some of ted's stuff....im definatly going to get an oem head gasket though. im torn between
1 - replacing my blown head gasket and going with arp head bolts and a new timing cover
2 - same as above and getting a doa timing chain set
3 - completly rebuilding up my spare motor and sourcing parts from varoius companys
im scared to find any internal damage when i pull the head off, i dont want to have to do this a third time. the head gasket blew after 6000km's....i did a compression test
#1 150
#2 135
#3 25
#4 25
i hope i dont have any bend valves...when the head gasket went (i hope thats all that happened) the truck had a BAD knock and am scared to find my port and polished head messed right up. id rather spend the money and build it myself with parts that i picked. i bought the motor from a guy on CL and im definatly paying for it now
Old Aug 31, 2009 | 10:06 PM
im arared to find any internal damage when i pull the head off, i donwantnt to have to do this a third time. the head gasket blew after 6000km'...i.i did a compression test
#1 150
#2 135
#3 25
#4 25
i hope i dont havany y bend valves...when the head gasket went (i hope thats althat t happened) the truck had a BAD knock and am scared to find my port and polished head messed right up. id rather spend the money and build it myself with parts that i picked. i bought the motor from a guy on CL and im definlylpaying fofor it now
1. Ted supply's a TURBO head gasket with his kit because it's stronger then stock
2. Timing cover alway's a good idea , I used Ted's head bolt's and they work fine
3. If I remember correctly TED builds the timing kits for Dead On Arrival and he relabel's them doa.
bigjstang
Jun 2, 2025 03:56 PM
dumpster84
Apr 30, 2016 06:03 AM
jerusry
Oct 19, 2015 05:28 PM
e_richard
Jul 30, 2015 06:50 PM
TransAmBandit
Jul 28, 2015 11:30 PM
