22re idle surging with A/C on
Old Aug 30, 2009 | 08:39 AM
93YotaMonster's Avatar
ok guys im still having trouble with my truck, i have a new problem wen i turn the ac on the idle starts to surge. the truck has a new IAC,cap,rotor button, spark plugs, and plug wires. the truck is a 93 22re 4wd mods are in my sig minus the MSD coil and accel plug wires
Old Aug 30, 2009 | 08:53 AM
abecedarian's Avatar
check for vacuum leaks. also that the a/c idle up adjustment isn't too high or low.
Old Aug 30, 2009 | 09:35 AM
how do i check the A/C idle up?
Old Aug 30, 2009 | 09:45 AM
on the side of the intake manifold is the a/c idle up valve- has what looks like a big screw on it:
With the a/c off, it does little to nothing, but when the a/c's on, it allows some air to bypass the throttle and raise the idle speed. Turn the screw in with the a/c on and the idle should lower and vice-versa.
Old Aug 30, 2009 | 09:51 AM
ok ile give it a try. thanks abe
smthwsn357
May 1, 2024 07:28 AM
MO transplant
Apr 23, 2023 11:58 AM
montanatruck
Feb 26, 2017 07:07 AM
jackiebrownia
Jul 20, 2015 09:02 AM
bryan34w
Jul 6, 2015 05:53 PM
