3.0 header solution/problem
Old Aug 31, 2009 | 01:19 PM
baseballchamp157's Avatar
Lightbulb 3.0 header solution/problem
now i was just wounderin today cause i just pulled out my 3.0 that i blew up. Instead of buying $800 headers, would it work if you cut the the exhaust manifold right before it bends behind the motor and clamp some flex pipe to it. would that be an easy solution? cause i sure cant afford headers. and this seems to me to be an easy solution, but i would like some other opinions too!
Old Aug 31, 2009 | 03:34 PM
come on guys, no comments on how stupid of an idea it is or how it wont work or nothin..lol
Old Aug 31, 2009 | 03:45 PM
OutlawMike's Avatar
I use flex pipe after the muffler, works fine.
But, up that high in the exhaust, there is a bit of pressure in there due to the Cat and the muffler. You might have a hard time getting it sealed at the manifold.
There is also the problem of how to attach to the driver's side, it will be custom, no matter what.
Keep us posted if you do this, it would be interesting to see if it works out.
Old Aug 31, 2009 | 03:59 PM
well its ganna be a mud truck so there aint ganna be no cat or muffler. i figure ill run it almost all the way out and then come out with pipe. that way i can have duels and it will be easy to manuver the flex pipe.
Old Aug 31, 2009 | 09:11 PM
Jay351's Avatar
Its called a crossover elimination. Cap off the flange on the drivers manifold, modify the flange on the passengers to face down.
Then just get a pipe bent up that fits up there and then join it to the drivers pipe near the trans. Keep the pipe relatively small..
Old Sep 1, 2009 | 04:10 AM
dude not to act supid but i have no idea what you just said
Old Sep 1, 2009 | 07:31 AM
BoostinChick's Avatar
https://www.yotatech.com/forums/f116...estions-90037/
https://www.yotatech.com/forums/f116...r-3-0-a-99518/
https://www.yotatech.com/forums/f116...61/index3.html
Old Sep 1, 2009 | 10:56 AM
ok now that makes more sence. cause im in between switching motors and i figured it would be easier while the motor is out. and while im at it im puttin in a new clutch kit.
Old Sep 1, 2009 | 11:10 AM
also how do you break in a clutch the right way? ive heard a few thangs about having to break in a new clutch or somethin like that
Old Sep 1, 2009 | 11:48 AM
Usually you wear it in for at least 300-500 miles of easy driving before really beating on it/going high RPM's.
Old Sep 1, 2009 | 11:58 AM
seriously cause this is just a mud truck and the farthest its ganna go without high rpms is about 100yards..lol
sanctfy
Sep 13, 2015 06:33 PM
josh21
Sep 9, 2015 03:26 PM
FJtoyman
Sep 8, 2015 04:47 AM
seab1209
Sep 3, 2015 05:41 PM
DiggnDeep
Sep 3, 2015 02:45 PM
