Body lift question
Old Jan 2, 2016 | 01:58 PM
mistershmi's Avatar
Body lift question
Im in the process of installing a body lift on my 93 pickup.
I wondered if it was a problem that the cab was just slightly forward. I pushed and lifted it and pushed some more but couldn't get it to slide back just slightly like maybe a centimeter...any ideas? Unless you don't think it will be a problem. Maybe I'm just being a perfectionist, lol.
Here are some pics of the front two mounts (the ones just behind the front bumper) so you can see what I mean :
Drivers side
Passenger side <br/>
Old Jan 3, 2016 | 05:51 PM
86toyotaprerunner14's Avatar
that would be just fine
Old Jan 4, 2016 | 02:40 AM
Zach_trun's Avatar
Body lift question
What kind of body lift did you buy? I also have a 93 pickup
Old Jan 4, 2016 | 07:47 AM
tj884Rdlx's Avatar
Why didn't you replace those dry rotted rubber bushings? Just going to wait for them to crumble away?
Old Jan 4, 2016 | 03:43 PM
Robert m's Avatar
x2
I hope the rest of the cab bushings don't look like that if you reused them.
Old Jan 4, 2016 | 04:54 PM
piglett's Avatar
those are age cracks
that means the truck is a classic
Old Jan 5, 2016 | 06:37 PM
mistershmi's Avatar
i bought the 2" kit from 4Crawler off road. FWIW, my pickups a 2wd. worked out pretty good, i like it so far.
Old Jan 5, 2016 | 06:39 PM
mistershmi's Avatar
Originally Posted by Robert m
x2
the rest were passable. i honestly was just trying to get it done by this point cause i needed done in time to drive to work. i was kinda bummed the kit didn't come with new ones (got the 4crawler 2" kit)
Old Jan 5, 2016 | 06:51 PM
mistershmi's Avatar
they actually weren't bad, i just needed to get the job done. ill keep my eye on them. wheres a good place to get replacements in the future?
Old Jan 21, 2016 | 02:41 PM
gyates93's Avatar
How much work was the installation vs the gain from 2" of lift? I'm thinking of going a little bigger for tires but I don't really want to alter the IFS because the truck is 90% daily driver. Did you have any problem with things like wiring and controls that go from the cab to the frame?
Old Jan 21, 2016 | 08:24 PM
mistershmi's Avatar
Installation was fairly straightforward. I'm by no means experienced, but was able to do it on a saturday (probably about 6 hours). From what I've heard (mostly from Robert M) the 2" of body lift is essential if i want to avoid tires rubbing - I'm going to be putting on 235 75/15. We'll see soon (haven't put the tires on yet) but I think the body lift will save me from having to crank the stock torsions up and ruin the ride. (I plan to get some sway aways when i have the money though)
I had no problems with 2" - 4crawler off road says 2" is the most before you start having to do mods. He has an amazing write up that I used the whole way through it so I would check it out for sure. he gave me an adapter bracket for the front bumper and radiator, but i didn't even need the radiator one. Ill probably put it on soon anyway just so that i can get max efficiency from the fan though - i had to remove the lower portion of the fan shroud. I also plan to get the drive shaft 1" extension but i could get away without it TBH.
Old Jan 31, 2016 | 05:01 AM
tj884Rdlx's Avatar
I put in the urethane kit. Fourwheelparts or Summit Racing.
Always replace those UV-wasted rubber bits!
But fyi: 235s fit without any mods. 31s will fit now with your 2" blocks.
shisha1999
Mar 3, 2016 07:28 PM
Hugh_Mann
Dec 22, 2015 05:27 PM
drk421
Nov 20, 2015 09:40 PM
Finelygotone
Nov 18, 2015 08:35 AM
Whitemoneypit
20
Nov 1, 2015 10:20 AM
