Help With Upper Idler
Old Dec 31, 2015 | 09:58 PM
SunnyCoastSteve's Avatar
Ok, a little background. 92 3VZ MT. Replaced TB/WP/Pulleys 20K ago. Over the past 5K I have noticed what seems to be a noisy bearing. I couldn't pinpoint it, but suspected the dummy water pump or viscous fan hub. Replaced the fan hub with a new Aisin, no change in noise but the old one was due to go. I don't have a stethoscope, so used the long screwdriver & hunted around until a put it on the radiator hose end of the upper pulley. My head was physically moving on the screwdriver & the coolant was shaking in the radiator as I took the cap off to have a look. So I think I found the problem. I removed the TB cover & all looks well but I suspected that the upper bearing would at least have some slop in it. All I can get is about 1mm front to back movement. it doesn't "crunch" when I spin it (TB is still on & I can spin with my hand enough to hear/feel problems but is still under some tension from belt) From all of the collective experience here, is there anything that comes to mind, other than the idler? Is that much play enough to cause that level of vibration? If the belt was off, would I get more play? A mechanic friend, not familiar with the 3.0, listened & said definitely not internal, so that's something I guess. He also said that he would not drive it with that sort of vibration as I was due to go up the beach for a week. Any help would be greatly appreciated. I am by no means a mechanic, just handy at best when I have the FSM.
Thanks,
Steve (from Aus)
Old Jan 1, 2016 | 02:38 PM
No-one has any thoughts?
Old Jan 2, 2016 | 05:16 PM
MudHippy's Avatar
1mm of play is WAY TOO MUCH. New they have none. I have 2 used ones that have over 200K miles use each. Neither one has close to 1mm of play. Barely any play detectable on the worst one(.25mm at best).
I can't say for sure if that's what's causing the vibration. But it seems like there's a chance it could be.
Just keep throwing money at it. That's what I do. You'll get it eventually.
Old Jan 3, 2016 | 04:39 AM
Hey MudHippy,
thanks for the reply. Idler was a Koyo, which I think are reputable. Thought I may as well do the valve cover gaskets & all associated bits at the same time. That idler is much easier to get to with the plenum off. Just wondering if I should replace the TB & other idler as they are only 20K old. Don't want to tackle that crank bolt again if I don't have to.
Thanks Again.
Old Jan 3, 2016 | 05:50 AM
MudHippy's Avatar
Yeah...I guess they're cheap enough. It's the upper idler that's spendy(for a good one).
