Crank, No Start. Need Some Help
Old Nov 28, 2015 | 02:01 PM
ign_cas's Avatar
1987 4Runner 22re Stick Shift
My truck is having some problems. I started it one morning and it ran good. Then I heard a loud ring going out the driveway (seemed to be from my radio) so I shut the truck off. Then when I went to restart it, it wouldn't start.
A day passed and I unhooked the battery and rehooked it back up together. Also noticed one of my vacuum lines to the canister was off so I hooked it back up. Then I go to start it and it started right up.
I started the truck up 3 times during the day and used it and all worked fine.
The next morning I go to start the truck and it won't start. It went back to cranking but no start.
The battery is good. I have spark to all plugs. The cranking is normal just won't start.
Any suggestions? Thanks.
Old Nov 28, 2015 | 06:22 PM
5280jo's Avatar
Check your fuel pump.
Old Nov 29, 2015 | 01:47 AM
jennygirl's Avatar
+1
You can also try running a jumper wire between Fp + B in your diag box under the hood, that will force the fuel pump on when the key is in the on position. If that solves your start issue, then you have a problem with either the circuit opening relay or the fuel switch in the AFM
Old Dec 5, 2015 | 10:53 AM
ign_cas's Avatar
Thanks for the diagram. I replaced the air flow meter with another used one I had and I still have the same problem.
I shorted those two terminals and didn't feel any pressure in the fuel line and couldn't hear the pump run.
I put my multimeter to to fuel pump and got 10.4V only while cranking. And the I didn't hear the pump run while I was cranking.
Does that automatically mean it's a bad fuel pump? Or can it still be something else?
Thanks for the help.
Old Dec 5, 2015 | 12:08 PM
scope103's Avatar
Nothing is automatic, but a bad pump is my guess. The FP line goes straight to the pump, so if you have 10.4v there and no pump noise, I would guess the pump is seized.
I would do one more check of the FP line right at the top of the tank before I pulled out the pump; you could have a wiring issue. You should get the same voltage at the FP line at the tank as you do at the diagnostic connector.
Old Dec 5, 2015 | 04:34 PM
ign_cas's Avatar
I shorted Fp and B+ and measured 12.1V at the pump with the ignition on.
The pump did not run. No pressure was built.
Is there another step? Or can I conclude that the pump is bad?
Thanks again.
ladybugRC
458
Aug 21, 2020 10:41 AM
voiddweller
53
Feb 1, 2016 05:46 AM
bradahman
Oct 1, 2015 09:24 AM
toyotasaurus
Sep 24, 2015 03:30 PM
TransAmBandit
Sep 20, 2015 06:08 PM
