22re missing, stumbling when warm
Old Jan 8, 2016 | 07:11 AM
JDaniels's Avatar
22re missing, stumbling ONLY when warm
What's up guys. New here to yota tech, I've searched many threads on my issue and I cant seem to find the culprit for mine.
Truck is a 89 22re it's bored .30 over with cam and exhaust. It's my first toyota and I'm in love. However the truck does not want to run good when warm. I usually see problems when I drive 20+ miles and turn the truck off to go in a store or something for 30 minutes when I come back out the truck will crank but it misses and seems it's running on maybe 2 cylinders if you let it cool down it will be fine and fire right up, sometimes the gas pedal can be feathered and it will seem to catch and idol normal and be just fine. I've checked plugs, wires, rotor button, all connections I could see like grounds there all tight. I changed coolant temp sensor and thermal time switch. Also fuel filter. I'm trying to stay positive because it runs so good until this starts happening but I'm getting really frustrated any thoughts or suggestions are greatly appreciated!
Old Jan 8, 2016 | 08:52 AM
tj884Rdlx's Avatar
How's your timing?
Old Jan 8, 2016 | 11:01 AM
JDaniels's Avatar
I'll have a look at the timing. I don't have the tools but a friend does. What should it be set at?
Old Jan 8, 2016 | 02:06 PM
d-wood's Avatar
My truck is a 22re 1993 and it says my ignition timing is 5degrees btdc.
jstluise
Jul 1, 2020 10:50 AM
yotapwru
Washington
Oct 22, 2015 09:08 AM
ET
Oct 22, 2015 01:37 AM
Benjamin Kloos
Oct 19, 2015 12:49 PM
mskater
Oct 13, 2015 09:08 AM
