DIYPNP on a 22RE, Anyone?
Old Oct 28, 2009 | 09:58 AM
mcm375's Avatar
http://diyautotune.com/diypnp/index.html
Here's one guys write up and docs on a 22RET, http://www.diyautotune.com/diypnp/ap...-22rte-mt.html
I am assuming a 22RE would be essentially the same, does anyone have real world experience with this?
Old Oct 28, 2009 | 01:06 PM
Matt16's Avatar
A gay friend of mine tells me that PNP is an acronym for Party And Play which apparently is sort of a swingers party with just guys. No real world experience with this DIY PNP, so unfortunately, I can offer no insight. What does this have to do with 22REs anyways???
Old Oct 28, 2009 | 01:09 PM
Magnusian's Avatar
From: Downtown Heckronto, Ontario, Soviet Canuckistan
I think it's an ECU replacement/bypass for tuning the EFI system. At least that's what I gathered.
Old Oct 28, 2009 | 06:54 PM
mcm375's Avatar
Yes it's a complete ECU whereby you can use more modern/reliable/accurate devices for measuring air (among other things, including wideband O2s). Someone has done it for a 22RET, so wondering if anyone had for a 22RE. My understanding is aside from any kind of boost control and the air/fuel maps, the two motors should be fairly similar in terms of ECU pinouts etc.
The DIYPNP kit basically can be plugged into your harness and swapped out within a few seconds, making it something that would be easy to develop/work on while still having a daily driver. Converting to a MAF and getting rid of the ^&*!#@( VAFM appeals to me.
You can do all sorts of other things with the aux inputs and outputs also; e.g., fan control, boost control for forced induction motors, etc.
Old Oct 28, 2009 | 07:08 PM
weaselman's Avatar
wtf?? click on the link and read. it has everything to do with 22re's
Old Oct 28, 2009 | 07:10 PM
muddpigg's Avatar
Judging by my last emissions test which was a 4 gas analyse. Why would you need to better adjust the fuel above what the factory ECU does. I've not got the most heavily modded 22re out there but quite a bit more than stock. Perhaps it you had a stoker or I can see a turbo if running significantly higher than stock boost. Just don't see the value in reinventing the wheel.
Or did I miss something?
Old Oct 28, 2009 | 08:42 PM
Matt16's Avatar
I guess you're one of those people who needs a "JK LOLOL", "HAHAHA", laugh trck or "" beside stuff to know when someone is joking and when its ok to laugh ()
Old Oct 29, 2009 | 10:01 AM
mcm375's Avatar
I think if you have a longer term plan to go there, yes that is where it would make total sense. Aside from that, there's a lot that can be simplified on the motor by going here esp when it comes to intake & throttle + flexibility + tunability.
I am already looking at needing to buy a new VAFM, and MegaSquirt setups have always been fairly cheap all up (compared to the bigger commercial/racing products).
Old Oct 29, 2009 | 10:10 AM
TOYOTA 1's Avatar
ya cus its so easy to tell over the interwebs
Old Oct 29, 2009 | 10:12 AM
BigBluePile's Avatar
I thought it was funny Matt...
Old Oct 29, 2009 | 10:23 AM
muddpigg's Avatar
Get it set it up and do a write up. Of course we'd like to see a dyno graph pre and post. and Gas analysis too.
Old Oct 29, 2009 | 10:32 AM
mcm375's Avatar
Useful lot you are...
Old Oct 29, 2009 | 10:46 AM
You are welcome.
Old Oct 29, 2009 | 10:50 AM
muddpigg's Avatar
Anytime thats what we're here for
Old Oct 29, 2009 | 05:59 PM
Matt16's Avatar
Have you checked out the "oil cap" thread, because it answer's your exact question... on page 793 or something.
Old Oct 29, 2009 | 06:02 PM
peow130's Avatar
If you want something simpler, with more power, put a 20R head with cams on a 22R, and run it carbed...
Old Oct 30, 2009 | 03:57 AM
jimep's Avatar
+1 on the 20 r, cam, carb and header for simplicity. I'd only recommend megasquirt or some other standalone if ur running some serious mods, turbo, or supercharger. It's not worth the hassle otherwise. I'm still debating on it because I've reached the limits on my factory turbo fuel injection but don't want to deal with tuning issues.
Old Oct 30, 2009 | 06:02 AM
mcm375's Avatar
I don't think I could get away with that with CA Smog visual...
I'm much more likely to get away with a stock looking EFI motor that just has a MAF conversion and a benign looking air filter. The computer bits are going to be under the dash somewhere anyway.
Plus I'm more interested in EFI configurability. I have ZERO experience with carbs. Just not old enough (sorry)
Old Oct 30, 2009 | 06:04 AM
Bojangles's Avatar
I know this has nothing to do with the question, but i just clicked on the first one i saw. Im new here at yotatech and i really need to know how to post a thread so people can help me with my issues instead of me just helping people lol HELP PLEASE
Old Oct 30, 2009 | 10:52 AM
muddpigg's Avatar
Welcome, before you post, use the search button on the blue bar.
