camshaft replacement question
Old Nov 2, 2009 | 10:17 AM
volcomdork182's Avatar
hey sorry if this is a stupid question but: Do you have to remove the intake and exhaust manifold when replacing the camshaft or should i leave them on for pressure so the head doesn't move? I want to be cheap and not replace my head gasket being as my engine has under 10,000 miles. I know you have to drain out all the coolant in the head by the plug at the back. but is there anything else i should be worried about thanks.
Old Nov 2, 2009 | 10:36 AM
snobdds's Avatar
The only way we can help is if you give us some specifics on your type of engine, etc. Otherwise it's just a shot in the dark
Ya dig...
Old Nov 2, 2009 | 10:45 AM
oh sorry thought i had it in my sig. I have a 87 toyota 4runner 22re, 5 speed manual.
Old Nov 2, 2009 | 11:57 AM
yeah i do my baby's mom's family has a auto shop and they can show me if needed but i put in my engine myself. i use to fix cnc machines so this is nothing compared to that. But the guy at engnbldr said make sure you do the coolant plug or it could blow the head. i didn't ask removing about removing the manifolds and i didn't want to bug him again so thank you that's all i needed.
Old Nov 2, 2009 | 02:38 PM
lukeland68w's Avatar
you dont have to remove the int/exh but drain the water in the radiator and block.
Old Nov 2, 2009 | 02:41 PM
make sure you start at TDC(top dead center) and distributor pointing to #1plug wire.
smthwsn357
May 1, 2024 07:28 AM
mskalmus
May 28, 2017 07:51 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
Avenged
Jul 9, 2015 07:55 AM
Cplmike
Jul 8, 2015 08:47 PM
