Oil is leaking out of top timing bolt hole cover
So I took off my air pump and left the bolts out...oil is bow coming from the upper bolt hole (that goes through the timing cover). Is this hole suppose to go through the block to an oil passage and what is the right way to plug it....with a copper washer, epoxy, ????
voiddweller
19
May 2, 2016 09:10 PM
JaredL
Jun 16, 2015 04:47 PM
