Speedo disassembly Question
Old Nov 3, 2009 | 08:35 AM
owenwalk's Avatar
My speedo gave out after 300K on my 87 4-cyl Runner. I have a cluster from a 6-cyl, but the tach is not calibrated for the 4 so it's not just a straight swap. I am hoping to extract the speedo portion from the good cluster to replace the busted one. So, I got as far as getting the clear plastic lens off, but cant figure where to go from there. I have tried prying off the speedometer needle, but it doesn't seem to want to come off. Does anyone know how to remove the speedo from the cluster???
Old Nov 3, 2009 | 09:04 AM
minimudder's Avatar
Here are links to the 2 post that i used to help me in my swap. They will both explain how to remove your speedo needle, and atleast one will explain changing out the odometer. My key words were, guage swap, for the search funtion. I hope this helps
https://www.yotatech.com/forums/f116...w-pics-179106/ (iamsuperbleader)
https://www.yotatech.com/forums/f115...ictures-51800/ (CastrolSi)
Old Nov 3, 2009 | 09:50 AM
Junkers88's Avatar
Why don't you just switch the V6 cluster from 6cyl calibration to 4cyl? It's a simple click if I recall correctly.
Old Nov 3, 2009 | 09:52 AM
owenwalk's Avatar
What do you mean by a simple click?
Old Nov 3, 2009 | 09:57 AM
Windsor's Avatar
Someone posted that their speedo needle broke when they forced it off, so tread lightly.
Mine came off with minimal fuss, fwiw.
Old Nov 3, 2009 | 10:05 AM
Junkers88's Avatar
There is a small white screw in the back of the tach with a phillips head. Turn it from 6cyl to 4cyl. *click*
I do not know which way it is supposed to turn since I've only seen pictures of the screw in some threads here. When I did my SR5 cluster swap the cluster was out of a 4cyl.
Old Nov 3, 2009 | 10:37 AM
owenwalk's Avatar
Thanks for the links, Minimudder. Thanks just what I was looking for.
Old Nov 3, 2009 | 10:40 AM
owenwalk's Avatar
That's too simple, Things should be more complicated and difficult...
Old Nov 3, 2009 | 10:41 AM
4Crawler's Avatar
Aftermarket tachs will have a switch for 4-6-8 cyls, but on the Toyota tachs, at least the earlier ones, you may need to do something like the following to re-calibrate them:
-http://www.mindspring.com/~jayk3/toyota/tachmod.htm
Old Nov 3, 2009 | 02:30 PM
iamsuperbleeder's Avatar
I don't think the tach adjustment screw in the cluster is a "click" mechanism... I think it's a standard pointometer that you have to dial in with a multimeter... or am I wrong...
Old Nov 3, 2009 | 03:08 PM
minimudder's Avatar
You are welcome Owenwalk, keep us updated.
foampile
Dec 18, 2022 01:29 PM
Dieselmann
Feb 19, 2019 02:57 AM
94ofCanada
Aug 14, 2015 06:37 AM
Pedalpwr27
Aug 13, 2015 06:37 AM
JAmdor3
Aug 11, 2015 10:53 AM
