Clogged breather = blown axle seal
Old Nov 2, 2009 | 10:45 AM
GodwinAustin's Avatar
Make sure you check the breathers on your diff!
Despite numerous postings on the topic, and knowledge of what a clogged diff breather can do, I didnt check mine on my "new" 88 4runner and have gear oil all over my drum, wheel and tire. I just hope its only the inner seal, though I am guessing its both.
At least this is an opportunity to put on an extended breather.
Old Nov 2, 2009 | 11:04 AM
toyota4x4907's Avatar
I bet thats why my rear pinion seal was leaking (fixed) and why the front seals are leaking on both sides of the shaft housings. Stupid PO didnt do hardly ANY maintenance
Old Nov 2, 2009 | 11:17 AM
03vrod's Avatar
That's one of the most important things we check on our PM's.Saves a lot of work on those big nasty trucks if you keep those things open
Old Nov 15, 2009 | 01:33 PM
Ended up freeing up the existing breather and that seems to have temporarily stopped the axle seal leak - going to add the extended breather, and then keep an eye for any new gear oil.
Old Nov 15, 2009 | 03:39 PM
myyota's Avatar
You should pull the brake drum and clean the gear oil off of the brake surface and also check the brake shoes.
jasonty
41
Dec 23, 2018 01:00 PM
polo451
13
Nov 20, 2016 07:49 PM
jerusry
Oct 19, 2015 05:28 PM
yourrealdad
Jul 21, 2015 11:13 AM
scottyg486
Jul 19, 2015 05:34 PM
