Transmission Rebuild kit
Hi, I have a 92 Toyota pickup Xtracab with the V6 and R150F tranny. The transmission synchros were going bad so I swapped transmissions only to have the new tranny be much worse than the old one. So I decided to take up the challenge of rebuilding it myself. I was looking on CobraTransmissions for rebuild kits and I'm a little confused on which I should get. The part numbers I found that sounded right were CT-BK163WS and CT-BK163DWS. I'm just unsure of what synchros or rear main shaft bearing diameter I would need for my year transmission. Thank you for any help.
