possible clutch issue
Old Mar 15, 2019 | 09:56 AM
keycw's Avatar
5 Year Member
hey guys, 1987 runner with 22re and 256b 5sp. I recently finished installing my new marlin built w56b, new marlin 1200lb clutch with everything new. new bearings, new flywheel, even the little clips for the bearing cup. test drove it down the road, then to town, felt great. went to drive it popped out of second gear on me twice. I THINK its a clutch issue. my question is, with a new heavy duty clutch setup like this where should I adjust the clutch pedal rod to? it was catching pretty far down on the pedal, and I think with a new clutch like this is should be pretty high up right? hydraulics look good, new slave and new lines and new fluid. master is working fine. after it popped out of second I put it in first and drove it the remaining 1/8 mile into my driveway (lucky I was almost home).
Old Mar 15, 2019 | 12:26 PM
akwheeler's Avatar
Popping out of gear usually isn't a clutch issue, that would be either slipping or hard shifting.
I'm not sure what the "little clips for the bearing cup" are, but did you put in a new pilot bearing?
Check to be sure your shifter isn't contacting the floor board and maybe keeping you from shifting completely into 2nd.
Old Mar 15, 2019 | 01:30 PM
keycw's Avatar
5 Year Member
i was just trying to give an example as to how thorough i was with the job. the clips hold the throwout bearing cup onto the shift fork. yes i replaced the pilot bearing. complete list of replaced parts includes transmission, tranny to tcase gasket, rear main, pilot, throughout, flywheel, pressure plate, clutch, all driveshaft ujoints, front cardan dust shield. i used GL5 oil to fill the transmission, i know some people will say that it will only run well with GL4, could this be the issue? i just tried to drive her again and same results. will go into 1st, take off fine, then once in second pops out after a few feet. same if i try to go from 1 to 3. it doesnt pop out of 1st. fluid levels are fine. i guess i was mistaken about the clutch issue its not a transmission issue. i serioudly doubt a marlin tranny with 8 miles on it is bad, which leads me to operator error, and the only thing ive done is fill it with fluid. any takers? i checked for the shifter clearance at the floor pan and it looks fine.
Old Mar 15, 2019 | 03:13 PM
akwheeler's Avatar
I would suggest that you contact customer support at Marlin Crawler, that sounds like an issue with the new transmission to me.
Even the best companies end up with failures on new equipment occasionally.
Old Mar 16, 2019 | 09:02 AM
keycw's Avatar
5 Year Member
so i drained the gl5 and replaced with gl4 as per marlins instructions. i went for a few spins around the neighborhood and it seems to only pop out of 2nd. i can get into 3rd fine, and all the way up to 5th with no problems. i tried getting through to marlins help line yesterday about 25 times with no success so i have emailed them. it feels like its popping out after i let off the throttle.
Old Mar 18, 2019 | 07:44 AM
keycw's Avatar
5 Year Member
well I spoke with marlin. basically they said its the transmission. they told me to pull it..again..and mail it back to them using the box and label for my core, which means no core refund any time soon. kinda really aggravated.
Old Mar 18, 2019 | 11:01 AM
akwheeler's Avatar
Yes, it's aggravating, but it keeps you from running down the rabbit hole regarding "what did I do?" or "is it the fluid, the clutch, the shifter?"
I always recommend that if you have an issue with a new engine or transmission that can't be readily explained contact the maker early in the process and see what they say.
If it is something you did wrong you probably are not the first one it has happened to and they can tell you what to check, or in your case they verified that it's inside the tranny and their responsibility.
Of course that is unless they find evidence of damage due to improper installation or abuse.
Fear not, you will have it back fairly soon and you'll be on the road before you know it.
Old Mar 19, 2019 | 08:23 AM
ev13wt's Avatar
5 Year Member
Stuff like this is just a big hassle. You bought from Marlin, everything will (should!) turn out ok.
You could have bought some random ebay remanned transmission. Good luck in that situation with a gear popping out.
Old Apr 11, 2019 | 05:01 AM
keycw's Avatar
5 Year Member
i wanted to follow up with this post because I know a few people were curious to see results. I spoke with marlin while they had my transmission. they told me there was nothing wrong with the transmission, they also told me if it was popping out of gear the issue HAD to be internal... so I was pretty frustrated. they decided to replace most of the internals anyways and ship it back. I spend my afternoon and night reinstalling everything. im getting pretty good at it haha, I started the install at 1815 and finished at 2230, by myself with no lift id say that's good time. I drove the truck and shortly after getting out of my driveway it popped out of second again. all other gears fine. I decided to drive it for a while anyways. I only changed ONE thing after putting the tranny back in, I decided to ditch the parts store off the shelf gl4/gl5 gear oil and I ordered redline mt90. after making a few laps around my neighborhood the issue resolved itself. it shifts smoother, and does not pop out of gear anymore... I really don't know what to make of the situation. by my method of issue resolution, if I had a problem, and the only thing I changed was the fluid, im lead to believe it had something to do with it. but I also call BS on that haha. I will call marlin and tell them today. I drove the truck to work today (45 mins) with no issues. will update if the problem comes back. thanks guys.
Old Apr 11, 2019 | 06:07 AM
coryc85's Avatar
Well, redline claims that normal GL5 oils are too slippery for manual transmissions and their oil has the right coefficient of friction. I've always put plain old part store gear oil in mine, I did change to synthetic not that long ago, but never had any issues with either conventional or synthetic part store stuff. Maybe next time I'll try the redline.
Old Apr 11, 2019 | 11:08 AM
ev13wt's Avatar
5 Year Member
Interested in hearing about the outcome of this.
Old Apr 11, 2019 | 11:16 AM
keycw's Avatar
5 Year Member
not really much left for me to say unless the transmission starts popping out of gear again. all I can do is drive the hell out of her and enjoy it I guess. marlin already said theres nothing they can do, and there aren't any more parts I can replace haha.
Old Apr 11, 2019 | 11:18 AM
keycw's Avatar
5 Year Member
I even drove her to work this morning I was feeling so good about its shifting! 45 minute drive and no issues, and about 25 mins of that drive is slow and shifting through lower gears often.
RASALIBRE's Avatar
That’s the problem with part swapping, money spent and no knowledge gained.
Old Apr 11, 2019 | 12:09 PM
Melrose 4r's Avatar
5 Year Member
Great looking rig!
Old Apr 11, 2019 | 01:54 PM
jakey poo's Avatar
What he said ^^^^^
Old Apr 11, 2019 | 05:58 PM
keycw's Avatar
5 Year Member
what parts were swapped with no knowledge gained? other than the transmission on course, but that was at Marlins request.
Old Apr 11, 2019 | 05:59 PM
Paul22RE's Avatar
5 Year Member
Originally Posted by Melrose 4r
Great looking rig!
Agreed!
buckleycoldnwet
Mar 26, 2017 06:57 AM
norm0931
Oct 8, 2012 11:17 AM
Junkers88
Aug 7, 2008 03:37 AM
'97_5-speed_stroker
Jan 6, 2008 06:04 PM
TS86
Aug 24, 2005 08:26 AM
