Best way to clean up engine wire harness?
Old May 14, 2019 | 10:38 AM
Learning's Avatar
The engine wire harness looks dirty and some filth inside the connectors. I am thinking of using purple power concentrate mixture with water and soak it in a bucket. Or using electronics cleaner and spray the connectors to get rid of dirt, grime, etc. The engine wire harness is attached inside the engine bay, minus the engine itself, leaving a lot of empty space to work with the engine wire harness Any ideas on this issue? Comments, feedback, advice is greatly appreciated
Old May 14, 2019 | 11:11 AM
keycw's Avatar
5 Year Member
purple power could cause some corrosion, I would thin the best answer is a soft brush and electronic cleaner, or possibly an alcohol solution, although that might not be the quickest solution its probably the better answer.
Old May 14, 2019 | 11:50 AM
ev13wt's Avatar
5 Year Member
Maybe deoxit the connections and then protect them.
Clean with a damp rag, don't dunk it.
Next time leave everything attached to the engine. Pull the plug from the computer and lay it on the engine.
Old May 14, 2019 | 01:11 PM
Learning's Avatar
ev13wt and keycw, thank you both for your comments. I appreciated it.
I remembered that I did read somewhere about Purple Power can cause corrosion on the engine wire harness awhile back. I think it would be best to use Electronics Cleaner and wipe excessive moisture and dirt combine using a soft brush and rags to clean it up. Thanks again.
DH6twinotter
Nov 18, 2006 05:12 PM
jjenks0
Jun 7, 2006 05:51 AM
L33T35T 4Runner
12
Feb 16, 2003 12:26 PM
UKMyers
Aug 6, 2002 11:15 AM
