Coolant temp sensor testing needs to be done at all different temps?
Old May 2, 2019 | 11:14 AM
Paul22RE's Avatar
5 Year Member
Or can I assume the ECU coolant thermo sensor is OK if it's within specs at the current temp?
92 22RE
Thanks.
Old May 2, 2019 | 11:46 AM
Melrose 4r's Avatar
5 Year Member
I personally have had a HONDA coolant temp sensor fail and make the system think it was incredibly cold out, but the reading was still within the realm of possibility. So i'd take a couple readings at least, one cold and one at the temp you think you are experiencing the problem at.
Old May 2, 2019 | 11:54 AM
scope103's Avatar
The coolant temps sensor is not a switch, it's a thermistor. (But you knew that, because you were testing resistance.) http://web.archive.org/web/201311071...40engineco.pdf I don't "know" if you can make that assumption, but that's the one I would make. The failure modes that I can think of would all pull the measurement out of spec at room temperature, and pretty much any other temperature.
But if the sensor is out, my curiosity alone would make me dip into some boiling water.
Old May 2, 2019 | 08:28 PM
RAD4Runner's Avatar
Yep, measure resistance while dipped in boiling water and then while dipped in crushed ice.
Cmayer
Oct 9, 2013 12:39 PM
brino1
Jun 25, 2012 10:47 PM
nexgen91
26
Aug 1, 2010 09:36 PM
sharrack
Dec 8, 2009 08:11 AM
MIKEMOKAS
Nov 4, 2007 09:49 AM
