Cutting out around 4grand under load
Old Apr 2, 2019 | 04:40 PM
Dosmith05's Avatar
1995 Toyota 4runner
New injectors, new fuel filter, tune up.
Its running good but it just started to cut out around 4000 rpm.
Anyone else have this problem and have a solution?
Old Apr 4, 2019 | 05:59 AM
snippits's Avatar
Cutting out I gather you mean it's misfiring. You sure it's not slightly misfiring at lower rpm? And then at higher rpm it's more noticeable.
Old Apr 4, 2019 | 08:16 AM
Co_94_PU's Avatar
Check the stored codes.
Old Apr 4, 2019 | 02:53 PM
Dosmith05's Avatar
Okay will do
Old Apr 5, 2019 | 01:36 PM
ev13wt's Avatar
5 Year Member
Did it work fine before the tune up?
Old Apr 5, 2019 | 04:18 PM
Dosmith05's Avatar
Its definitely not a misfire.
It's like it just drops power and comes back.
I'm going to put a new TPS on it because that what its acting like.
Dosmith05's Avatar
Not to sure never really ran it much before the EGR delete.
Old Apr 5, 2019 | 06:26 PM
Robert m's Avatar
What's your ignition timing set at?
Old Apr 6, 2019 | 05:47 AM
Dosmith05's Avatar
5 degrees
Old Apr 6, 2019 | 01:08 PM
ev13wt's Avatar
5 Year Member
Originally Posted by Dosmith05
5 degrees
I have to ask with the jumper set? Does the idle drop when you set it?
Old May 15, 2019 | 07:28 PM
Dosmith05's Avatar
It was the hard plastic line from the fuel tank to the line on the frame.
The line was kinked.
Old May 15, 2019 | 07:29 PM
old87yota's Avatar
That would do it. Not enough fuel flow.
Thanks for posting what you found!
zombie_stomp
Jan 25, 2015 04:18 PM
gambitace71
Jun 14, 2012 03:55 PM
JBauer1215
Feb 13, 2011 07:06 AM
BADLNDS
Jul 15, 2005 04:55 PM
Randomness
May 21, 2005 03:07 PM
