Cutting out around 4grand under load
1995 Toyota 4runner
New injectors, new fuel filter, tune up. Its running good but it just started to cut out around 4000 rpm. Anyone else have this problem and have a solution? |
Cutting out I gather you mean it's misfiring. You sure it's not slightly misfiring at lower rpm? And then at higher rpm it's more noticeable.
Check the stored codes.
Okay will do
Did it work fine before the tune up?
Originally Posted by snippits
(Post 52421624)
It's like it just drops power and comes back. I'm going to put a new TPS on it because that what its acting like. |
Originally Posted by ev13wt
(Post 52421708)
What's your ignition timing set at?
Originally Posted by Robert m
(Post 52421726)
Originally Posted by Dosmith05
(Post 52421741)
5 degrees
It was the hard plastic line from the fuel tank to the line on the frame.
The line was kinked. |
That would do it. Not enough fuel flow.
Thanks for posting what you found! :safari: |
