Yup.....CV Boot time
Old Sep 30, 2007 | 05:24 PM
naadomail's Avatar
So my upper cv boots are totally torn asunder. They are simply laying on the axles. My question is. Is there a way to replace the upper boots without pulling the entire axle?
Old Sep 30, 2007 | 05:34 PM
corvey's Avatar
You could buy bolt on cv boots, but they are 2x-3x as expensive as the regular boots. I'd just do it the right way and take them off and replace each boot the correct way and feel good knowing you inspected, cleaned, and greased the joint thoroughly while it's off.
Old Sep 30, 2007 | 05:48 PM
naadomail's Avatar
I probably should......and will.......but for the now (seeing as I am broke from reworking my head) Tell me more about these bolt-ons. Also, I read in another post that the upper cv boots on my year model are easy to replace "only 6 bolts and a clamp" any truth?
Old Sep 30, 2007 | 06:03 PM
naadomail's Avatar
Found the thread again I believe it is the third to last post:
https://www.yotatech.com/forums/f116...-boots-115359/
Old Sep 30, 2007 | 06:51 PM
corvey's Avatar
Here you go, bolt on cv boots from Advanceautoparts.com
http://www.partsamerica.com/ProductD...pe=942&PTSet=A
Old Sep 30, 2007 | 07:00 PM
tc's Avatar
tc
Just replace the whole axle. They're not that tough to remove, and to do a boot job right, you need to remove it in order to clean it up, inspect it, and regrease anyways. Changing the boot just adds work and no benefit.
If they're that ripped, the grease has become contaminated and who knows what kind of damage has been done to the axle.
$60-70 after core at Autozone, Advance, etc with lifetime warranty
Old Sep 30, 2007 | 07:57 PM
naadomail's Avatar
yeah I see the benefit, and believe me they need replacing. There is mud/oil/grease/little rocks all up in there. Hmmmmm, I wonder if that has anything to do with going off-roading and fording that river up to the bumper....But I digress. I will probalby replace the whole deal but like i said, broke. I was just curious as to whether or not I could do it cheaper and easier.
Old Sep 30, 2007 | 08:05 PM
corvey's Avatar
If you've been off roading like that a lot and rocks and stuff are up inside the broken boot, it may be too late for you. If they were only busted, with no offroad use and no rocks, sand, etc were in it, it's probably still ok and just need new boots. Only way to find out is to clean them and inspect them yourself. If your want to save you'll need do it yourself and find out for sure. Though you should have $150 bucks in hand to prepare for the worse case scenario.
Old Sep 30, 2007 | 08:53 PM
tc's Avatar
tc
When it's all said and done, replacing the whole axle (which you can definitely do yourself) will cost you an extra $20 over the boot ... won't take long to save that up.
Old Oct 1, 2007 | 01:16 AM
ovrrdrive's Avatar
I agree, change the whole axle if you can. They're $69 at Autozone with a lifetime warramty. I punched a hole in a boot when I installed mine and stopped, took it back down and swapped it out for another no questions asked, and came back and installed it. I got to use the warranty before I even got it installed on the truck.
You'll be better off...
Old Oct 1, 2007 | 06:33 PM
naadomail's Avatar
Ha Ha, I think I'll just put off the repair and let these axles go until I have the money for a full swap. Laifetime warranty too good to pass up. I've heard a lot about the manual hub kit. Where do i find one, how much, and what will I see in the way of mpgs?
icentropy
Sep 16, 2020 02:47 PM
mskalmus
May 28, 2017 07:51 AM
Sep 4, 2015 09:27 AM
smiley52
Jul 11, 2015 05:16 AM
