wheel bearings rear...how to change?
Old Apr 20, 2007 | 05:19 PM
4bytruckin's Avatar
getting nice gratting sound from rear wheel bearing . any pics of how to change
Old Apr 20, 2007 | 05:54 PM
AH64ID's Avatar
never done it, but IIRC they are pressed on and off, as they are what holds the axle in....
Old Apr 20, 2007 | 06:03 PM
DeathCougar's Avatar
there is a C-clip to remove and a retainer that needs to be pressed off, as well as the bearings. C-clip and retainer are non-reusable parts.
Old Apr 20, 2007 | 06:19 PM
AH64ID's Avatar
where is the c-clip at?
Old Apr 20, 2007 | 06:21 PM
AH64ID's Avatar
nevermind.. found it
http://personal.utulsa.edu/~nathan-b...33rearaxle.pdf
Old Apr 20, 2007 | 06:23 PM
see this post: https://www.yotatech.com/forums/f116/snap-rear-axle-sheared-off-45mph-tire-went-ride-113260/
Old Apr 20, 2007 | 07:05 PM
4bytruckin's Avatar
still not showing how to remove/press in new bearing and what is a sst . i may be missing something here.
Old Apr 20, 2007 | 07:15 PM
That thread is just for reference. SST=Special Service Tool
Old Apr 23, 2007 | 07:33 PM
Jonnym's Avatar
no need to press them in and out- just bang the crap out of them on the ground.
-pull the axle out, stand it up with splines facing down.
-grab the backing plate and slam the whole thing down.
- it took me about 30 hits to get the bearing + spacer out. easy
- to put it back together put the backingplate on the ground.
- grab a piee of pipe that is larger than the axle diameter but smaller than the inner race.
- apply heavy obect to pound the bearing onto the axle.
-- the descriptiion isnt very good, but it's pretty obvious once it's apart...
i just changed mine last weeked, the brakes take about 5x longer than the brearings and seals.
good luck
Old Apr 23, 2007 | 09:04 PM
good luck
yea....or just get it done at a machine shop and save yourself the backyard redneck fix and just do it right the first time.
do NOT slam the splined end in to the ground, for god sakes.
Old Apr 23, 2007 | 11:14 PM
Jonnym's Avatar
i found that tip here on yotatech, and well it worked great. and there was NO damage to the splined end, it did more damage to the concrete...
redneck is a bit strong, if it had duct tape, bailing wire, or my sister involved, then it would be redneck- but this method is just 'get-er-done :-)
signing out from my metro-backyard
Old Apr 24, 2007 | 09:46 AM
sloth!'s Avatar
i have used the beat it into the ground method many times and it works great. put a board down on the concrete to protect the splines, and wear gloves to protect your hands from the backing plate. Make sure you remove the snap ring before you start. I also use tube to beat the bearings on. Search other bbs where people actually do there own work and you will find that this is the preferred way. Everyone should try it once so you can do it as a trail repair if you need to.
Old Apr 24, 2007 | 04:44 PM
leebee's Avatar
i can attest to the backyard method, unfortunately for me, even with the clip and retainer off, that bearing was not going anywhere. had to take it to a shop to get pressed off and on.
it can be very hard on the hands, the impact and vibration will leave your hands and arms tingling for a day or two!
lee
Old Apr 24, 2007 | 05:00 PM
SwampThing's Avatar
Hey now... Some of us rednecks might take offence to that! Not me though, I think that's a great idea, and guess I'll be doin mine tomorrow since I aint got no work
It's gonna be great not smellin 80w90 every time I walk by the right rear tire...
Old Apr 24, 2007 | 06:12 PM
waskillywabbit's Avatar
I'm about as redneck as they come...and I prefer tools...not the "slam" method.
Old Apr 24, 2007 | 06:35 PM
SwampThing's Avatar
Though unlike the rest of us rednecks we aint got no clam press
Old Apr 24, 2007 | 06:55 PM
rebult junk's Avatar
just finished mine using the slam trick for the out and parts of my ball joint press and 2 in box 4 ft longfor the in
. the job took 3.5 hrs through the day and had a 30 t press at my disposel
now no moore grind from the rear
thanks yota tech for the great info on this repair
Old Apr 24, 2007 | 07:45 PM
SwampThing's Avatar
Yeah, see I got a 17t press at my shop, but its more for pressing in wheel studs than for pressin in seals. Couldn't figure out a way to jerryrig it to press in the seal, so I'm glad to hear that ye ol bang it with a tube trick'll work.
bigjstang
Jun 2, 2025 03:56 PM
the1998sr5
15
Jul 14, 2020 08:35 PM
jasonty
41
Dec 23, 2018 01:00 PM
cars-guy
Jul 11, 2015 07:51 PM
Gamble_STi
Jul 7, 2015 07:54 PM
