New torsion bar problem
Old Apr 24, 2007 | 08:34 AM
swerks's Avatar
So I install new bars with new bolts, bolts go on without problem. next day I go back to make height adjustments and the drivers side seems to be siezed the lock nut came off with out problems. I have soaked in pb blaster and when i use a bigger cheater bar the nut begins to strip. any suggestions????
Old Apr 24, 2007 | 08:39 AM
swerks's Avatar
would it matter that I dont have both sides of ruck jacked up ????
Old Apr 24, 2007 | 08:43 AM
MMA_Alex's Avatar
you should have the whole front end jacked up, but if you're just adjusting one side you really only need that side jacked up. its amazing what a little heat will do to loosen up bolts. just make sure you're not going to blow anything nearby up with the torch.
Old Apr 24, 2007 | 08:05 PM
Bear80's Avatar
Your bolt is cocked in the frame. The torsion bar anchor mount is not in line with the bolt in the frame, either to far foward or back. This happened on both sides to me once and the only way was to keep turning the bolt and they ended up snapping. After that I went to the junk yard and got the improved anchors and mounting bolts off a '89-95 truck.
Old Apr 25, 2007 | 02:08 AM
swerks's Avatar
that is exactly what happened, I got it taken care of. I reused my older bolt.
Old Apr 25, 2007 | 02:17 AM
Bear80's Avatar
so you snapped the bolt and had to reuse your old one?
I really like the newer style that does not allow the bolt to pivot at any angle. The new ones only allow the bolt to pivot sideways not backward or forwards preventing your problem and the one I had.--of course this main change is on the frame and cannot be put on the older style. However they also improved the anchor and bolt, deleting the need for the lock nut--it makes adjusting a breez.
I feel for you, seems it's been a pain in the neck since the start. Hope everything goes well from here on out!
88sasturbotoy
Jan 30, 2026 01:57 PM
RatOmeter
Oct 22, 2015 03:17 PM
Sep 4, 2015 09:27 AM
coffey50
Jul 28, 2015 10:55 AM
DrZero
18
Jul 24, 2015 11:31 PM
