3.0 Gasping
Old Apr 26, 2007 | 08:24 AM
Elvota's Avatar
3.0 Gasping
Occasionally, my 3.0 feels and sounds like it is giving up around 3,500 - 4,000 RPM. Usually it pulls strong up to 4,200 or so. Strong being a relative term of course.
But sometimes the motor will start to fall flat on it's face once around 3,500. Engine starts to make what can best be described as a rasping sound, hollow almost... nothing grinding or mechanical.
Any guesses? Engine does have to be warm, but the occurrence is somewhat random and not very frequent.
Old Apr 26, 2007 | 08:58 AM
gonzo's Avatar
I'd start with a fuel filter and go from there. could be alot of things. start with the simple most likely first. Also when it does this stop and look at the cat. see if it's red or the pipe in front of it red. Could be the start of your cat getting plugged.
Just my 2c
Good luck
Old Apr 26, 2007 | 09:06 AM
MudHippy's Avatar
Another simple thing I've found to effect power in that range with mine is sparkplugs. Pull one and see if the electrode is rounded off at the edges, and check the gap if you want to reinstall it. Either one of those factors will cause inefficient spark, and some loss of power.
Old Apr 26, 2007 | 10:34 AM
taikowaza's Avatar
weasey cams
weasey's cams worked for my similar issue
Old Apr 26, 2007 | 06:24 PM
Mark in MD's Avatar
Have you replaced the alternator lately? I heard something similar in mine at around 3500. I assumed it was the cheap alternator pulley.
91yotapup
3.4 Swaps
Mar 5, 2019 10:41 AM
scott90
Oct 4, 2015 09:21 AM
Jdgarrison
Oct 1, 2015 05:22 PM
Jdgarrison
Oct 1, 2015 02:11 PM
93RedKrawler
Sep 29, 2015 02:50 PM
