Anyone own a Toyota Crawler with an Automatic Tranny?
Old Apr 18, 2007 | 07:42 PM
Traumahawk's Avatar
I have found the 4runner that I want to a T......Except it is an automatic. I have owned about 8 different 1st gen 4runners, but never an auto. Any opinions out there? I need feedback. It has 5:29 gears with 33" tires. Would the tranny have to be adjusted to change the shift points? (Don't know if that was done...but I assume) What do you guys think? This is the ONLY thing holding me back from getting it!
Old Apr 18, 2007 | 07:58 PM
tc's Avatar
tc
The ONLY problem with the autos is the ridiculously tall overdrive. If you're not going to run it on the highway, they're great. Obviously, a tranny cooler is essential.
If you ARE gonna run it on the highway, 33's will need 5.71's to hold the overdrive, and 35's are pretty much out of the question.
Old Apr 18, 2007 | 08:04 PM
Traumahawk's Avatar
TC, you have a private message! Thanks!
Old Apr 18, 2007 | 08:07 PM
tc's Avatar
tc
You have a reply!
1 other thing to note: you only have ONE option if you want to do double cases: Inchworm.
http://www.inchwormgear.com/store/pr...products_id=86
(not that that is a problem, just limits the availablility and price)
Old Apr 18, 2007 | 08:09 PM
thook's Avatar
Doesn't Mt. Goat have an auto?
Old Apr 18, 2007 | 08:12 PM
Traumahawk's Avatar
This truck would be used for light off-road and often a DD.
Old Apr 18, 2007 | 08:13 PM
Lysmachia's Avatar
I have 5.71's on 35's in a 2nd gen with an auto. I don;t think it is that bad. but yeah a tranny cooler was essential.. I can driver to moab - not any faster than 80-85 but I can do it.
I don't love this option as a daily driver tho'
Old Apr 18, 2007 | 08:16 PM
Traumahawk's Avatar
So does it suck going up I-70 into the mt's?
Old Apr 18, 2007 | 08:20 PM
coldwiz's Avatar
I have the auto in my '91 with 4.88's and 35's. On the hwy going uphill it is going to kick out of OD and a really strong headwind can cause problems but most of time OD and 80mph are no problem.
Another option for a crawler would be to ditch the A340H for an A340F(E?) out of a 3rd gen 4Runner or Taco. Marlin makes adapters for it.
Old Apr 18, 2007 | 08:29 PM
coldwiz's Avatar
http://www.4x4wire.com/toyota/tech/autocrawler/
Write up for putting A340F into a 2nd gen. They went thru some trouble with the speed sensor but I don't think you need it. I disconnected mine a while back as a test (was dreaming about putting in a crawler) and the truck shifted normal but an error code was created. Tranny speed sensor might be for cruise control but mine was removed so I dunno...
Old Apr 18, 2007 | 10:16 PM
slosurfer's Avatar
Originally Posted by tc
You have a reply!
There is another option
http://www.gearslug.com/
Old Apr 18, 2007 | 11:11 PM
Kaleb's Avatar
I have a SAS'd 94 4Runner with an auto transmission. Right now I am using the stock 4.56 gears, but plan on changing the rear diff and adding 5.29's front and rear. I dont have any problems getting up to speed. I top out at about 75mph.
Jun 1, 2021 01:51 PM
mskalmus
May 28, 2017 07:51 AM
Jnkml
Jul 6, 2015 01:20 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
