Valve Covers Leaking
Old Apr 20, 2007 | 09:47 AM
pete f's Avatar
"pete f passed away quietly in his sleep on July 13, 2008
My valve cover gaskets have been leaking for some time now. I plan on replacing them. I'm in the process of making up my parts list.
1. Valve cover gaskets
2. erg valve gaskets
3. intake manifold (top) gasket.
4. knock sensor wire
I hope I don't have to disturb any more than that. Taking TB/Plenum off to get to Pasenger side cover.
Any help?
Did I forget anything?
Old Apr 20, 2007 | 12:29 PM
thook's Avatar
PCV valve and grommet.....how old is that? Any vacuum hoses look aged? Wire harnesses? Hose clamps? See if the one coolant hose under the TB might need replacing.
Yep, not much is more frustrating half way into a job and finding something breaks and you're unprepared.
Old Apr 20, 2007 | 02:10 PM
pete f's Avatar
I'll add pcv valve and grommet to my list. I haven't ordered anything yet. I just got a torque wrench and some pb blaster.I'm not planning to start until monday or tuesday. Got all weekend to think about it.
pete
Old Apr 20, 2007 | 02:49 PM
TNRabbit's Avatar
You'll need to remove the intake manifold to get to the knock sensor to remove the wire, so you'll need the two botton gaskets for the intake as well.
Be VERY CAREFUL when you pull the plenum off; there is a little plastic nipple thingy (technical term, anyone?) that will break off if you don't pay attention.
Old Apr 20, 2007 | 04:34 PM
navyredneck's Avatar
Did the valve cover replacement, broke the plastic thingy (TVV valve), did the redneck fix which has worked very well
here's a link describing how I did the same thing that you want to do (minus breaking the TVV valve...):
https://www.yotatech.com/forums/f116/help-process-3vze-vlv-cover-gasket-job-90201/
Old Apr 20, 2007 | 05:39 PM
pete f's Avatar
tvv valve/Bottom Intake Gasket
https://www.yotatech.com/forums/showthread.php?t=90201
That's a great thread I put the book mark on that one. Thanks navyredneck
got the bottom intake gasket on my list thanks tnrabbit. Yeah I got all weekend to plan it.
Old Apr 20, 2007 | 06:16 PM
Toy-SkiTzo's Avatar
its a good idea to replace your heater hoses while you have it off, its so easy with the plenium off
Old Apr 20, 2007 | 08:08 PM
pete f's Avatar
Heater hoses look good but I got them on the list now. If I don't do them (Murphy's law)I don't want to say in november I should have done them in april.:
Old Apr 21, 2007 | 05:09 AM
pete f's Avatar
Well I'm headed to the parts store.If they got the valve cover gaskets. I'll order what they don't have and dive into this project when I get home .
thanks for the great support.
pete f
Old Apr 21, 2007 | 05:47 AM
pete f's Avatar
Well It's Saturday morning and I'm calling parts store and If they got the gaskets I'm diving into this mission.
Old Apr 21, 2007 | 06:28 AM
YotaJunky's Avatar
Make sure you've got something to clean off the top of the intake manifold. The old gasket will probably be baked on. You will need cleaning fluid, like brake cleaner fluid, acetone or mineral spirits. A small tube of RTV for the half moon areas are also needed.
Also, check you torque specs. The valve cover bolts shouldn't be too tight.
Here's another thread on the valve cover gasket replacement:
https://www.yotatech.com/forums/show...+gasket+troy65
Old Apr 21, 2007 | 07:18 AM
pete f's Avatar
Thanks troy...for the link
hope to get this under way soon
pete
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
Sep 4, 2015 09:27 AM
calderp
Jul 27, 2015 09:58 AM
keithporter83
Jul 18, 2015 12:37 PM
87blyota
Jul 10, 2015 04:31 AM
