idle surges up and down
Old Apr 23, 2007 | 06:01 PM
kev109's Avatar
can you guys tell me why my 1992 22r surges at idle about a minute after you start it when cold. could it be mass air flow senser? please help
Old Apr 23, 2007 | 06:17 PM
BeaterToyota's Avatar
Welcome to the forum.
I had a similar problem with mine and it turned out to be clogged up "cold air idle up valve" or whatever it is called. A shop fixed mine because I had the truck in for another repair already.
Run a search on here for "surging idle" and you will find tons of posts about it and various possibilities for what's causing yours.
Old Apr 23, 2007 | 06:25 PM
thook's Avatar
You have a Volume Air Flow meter. I don't mean to be a technical prick, but they are different.
Does it do this when you start the motor warm? Or just when it's cold? It could be your coolant temperature sender.
Have you done any keyword searches, yet? There are many threads on this subject.
Nevertheless...
Here's a troubleshooting guide. Favorite place it, download it, print it. It will be your best friend.
Factory Service Manual:http://personal.utulsa.edu/~nathan-b...sm/engine.html
Jump the yellow diagnostic plug with a paper clip....the little one of the two behind your air box on the fender wall and see if the check engine light flashes any codes.
Instructions and code guide...your other best friend:http://www.off-road.com/toyota/tech/codes/index.html
And welcome to Yotatech!
smthwsn357
May 1, 2024 07:28 AM
wafoogalla
Nov 2, 2016 11:02 AM
PBRaddict#1
Aug 22, 2015 11:34 PM
bighaydn
Aug 4, 2015 07:17 PM
Dakotaneu
Jul 27, 2015 12:03 AM
