Anybody else have trouble getting the 1st generation windows down?
Old Apr 29, 2007 | 07:11 PM
Lifelongtoy's Avatar
Question Anybody else have trouble getting the 1st generation windows down?
I haven't taken them apart yet, but is there a reason why they get so sticky?
Both of them, it's weird.
Old Apr 29, 2007 | 07:15 PM
paxil4x4's Avatar
Drama Queen/Banned
Window regulators shot
Channel that window slides up and down is dry and need silcone spray
Door inner sheet metal is cracked where channel bolts to at the front of the door. I have one seen this happen with 1 piece windows
Old Apr 29, 2007 | 07:17 PM
Robrt32's Avatar
I noticed mine are harder to roll down than up.. thats seemd a little weird to me.. I meant to lube the window channels when i put the door speakers in but it was getting dark and i forgot
Old Apr 29, 2007 | 07:34 PM
91TPU's Avatar
dont have a 1st gen but mine are rough on the way back up, and mine are roll up, i gotta get me some silicone lube given that summer is finally here...
Old Apr 29, 2007 | 07:45 PM
I guess it would help to mention that they are manual.
Old Apr 29, 2007 | 07:51 PM
DeathCougar's Avatar
yea, grease the tracks with silicon spray. that should help them slide easier
Old Apr 29, 2007 | 08:33 PM
dcg9381's Avatar
Rollers eventually wear.. Replace with JDM ones from ebay.
Old Apr 30, 2007 | 05:54 AM
RiNkY's Avatar
Mine roll down, it's getting them back up that is the problem. Tried searching for 'JDM' and come up with to many results. 'JDM Window' or 'JDM Toyota' don't seem to help on Ebay either. Be more specific dude! lol. What is the name of the part?
Old Apr 30, 2007 | 12:03 PM
paxil4x4's Avatar
Drama Queen/Banned
There is no difference between JDM and USDM regulators on eBay the latter people will pay more money for because they are ignorant.
BTW a majority window regulators on eBay are aftermarket Taiwan anyways
JDM= Japan Domestic Market
USDM= United States Domestic Market
Old Apr 30, 2007 | 12:11 PM
ewong's Avatar
we talking passenger doors or the rear tailgate?
Lube the regulator channels.
The rear tailgate - the gear starts to strip...
Old Apr 30, 2007 | 01:07 PM
ohio's Avatar
It's not the regulators, it's the trim that's worn out. The felt wears away and just leaves smooth rubber which grips the glass and t6hen cocks the window to an angle. The only good solution is to replace the whole window trim/guide, which is a pain and not that cheap. A dry lube like graphite is a decent temporary fix but only seems to last about a week or half a dozen roll-downs.
Old Apr 30, 2007 | 01:11 PM
ewong's Avatar
Originally Posted by ohio
It's not the regulators, it's the trim that's worn out. .
The rear window hsa felt
The drivers/passenger doors (at least the vented window ones) have rubber only in the track...
I lube me wiht a smidge of dilectric grease...
Old Apr 30, 2007 | 05:24 PM
One more thing, the colder or wetter it is the harder it is to get down. On a hot day they go up and down easy.
Old Dec 28, 2007 | 07:35 AM
helikyler's Avatar
Toyota Window Sticks
I have the same problem with my 4Runner... when it's rainy or really humid (I live in Florida) they stick and don't want to go easily. Now the rubber seal has been pulled away from the door frame and it comes down and up with it every time. What a nightmare. I'm going to try that silicone stuff and I suggest the same. If you already tried it, let me know what you came up with.
Old Dec 28, 2007 | 07:57 AM
AxleIke's Avatar
Just a possibility, but have you ever replaced the windows? There are like 3 models of first gen windows. If you get the wrong one, it WILL NOT go up and down easily.
I'm assuming this isn't the case. But, just in case, or for others with issues, it might be useful.
Old Dec 28, 2007 | 08:00 AM
CanTheWhales's Avatar
It's just the rubber in the side tracks/guides that are sticking to the window, just lube it up or replace it, but remember, it goes all the way down in the door so be sure to spray that part too (take off door panel). I've done this, my problem is I didn't do it soon enough and my P/S window isn't "clamped-in" on the bottom anymore so I have to push it down when I crank or it will just stay up and fall out of position. Kinda rambly, but I hope this helps...
Old Dec 28, 2007 | 07:00 PM
Luvmeye22re's Avatar
I had that problem with my first gen (80 4x4) and my problem turned out to be that the bolt holding the regulator down was loose. Tightened it up and it started rolling down the way it should. It was also easier to roll up so the symptoms aren't too far off.
Old Dec 28, 2007 | 11:49 PM
AxleIke's Avatar
Originally Posted by yota4runna
Let's see..... With wing window, without wing window,......uhhh, number three escapes me. You certainly can't confuse the first two.
Nope.
There are three different wing window types. My driver side window was smashed out when my stereo was stolen, so I went down to the junk yard, and picked up a new one. It wouldn't go up or down without a fight, even with liberal silicone spray. Ended up trashing my regulator. Finally took it to a guy I know at the stealership, where I was informed of this difference. They have different part numbers, and the guys there refer to them as clear, gray, and gold, for the tints they originally came from the factory with. I needed a gray, I had a gold. Put the new window in, and it went up and down as smooth as a baby's bottom.
Old Dec 29, 2007 | 12:17 AM
notanymore's Avatar
mine arnt bad untill it rains or is really humid then they are a pain in the butt to get up and down.
okamikai
Apr 30, 2018 10:19 PM
mskalmus
May 28, 2017 07:51 AM
defrag4
Jul 31, 2015 10:50 AM
sabine
Jul 18, 2015 03:59 PM
coryc85
Jul 6, 2015 04:07 AM
