putting my window in, glue?
Old Apr 28, 2007 | 11:00 PM
91muddog's Avatar
im to thepoing where my new diverside window is ready to go in on my 94 4runner, now, the part that bolts to the regulator, how should i secure that to the glass? i want it to work smoothly and outlast the truck.
an good solid solutions?
Old Apr 29, 2007 | 07:17 AM
91muddog's Avatar
still looking for a solution
Old Apr 29, 2007 | 07:22 AM
4bytruckin's Avatar
j-b weld?
Old Apr 29, 2007 | 08:27 AM
mt_goat's Avatar
What's the FSM say?
Old Apr 29, 2007 | 03:01 PM
4runnerx3's Avatar
butyl tape?
Old Apr 29, 2007 | 04:47 PM
navyredneck's Avatar
I went to autozone and got some of that glue they use to glue a windshield back onto a vehicle. It's a black almost like silicone stuff. Anyway, I pressed the metal slides on the bottom and had to use a rubber mallet to get them on all the way. Right before I did that I coated all surfaces with a thin layer of that stuff. So far it has done the trick for me.
Old Apr 29, 2007 | 05:15 PM
89macrunner's Avatar
i would have used clear silicone. or urethane
black silicone will show up..butyl makes an insane mess
Old Apr 29, 2007 | 07:32 PM
I don't care if it shows up because it's on the channel guides which are on the bottom of the window and never show. Outside of tearing apart your door have you ever seen a channel guide?
Seriously, if I had known what the stuff was I would have used silicone because it's cheaper but that's because I'm a redneck and like to save a dollar. So in that sense, I agree with you, 89macrunner.
Whatever you use will probably be okay. Just make sure it's something that will stick to both glass and metal and will have some elastic properties and not just crack everytime there's a little movement and you actually need a material that can be removed (think of your next broken window replacement).
Show us some pictures when you're done. I was doing a thread on here and then my wife deleted all the pictures I took the day I put it back together...
Old Apr 29, 2007 | 09:44 PM
91muddog's Avatar
ill post some pics of puttiong it back together.
if it doesnt come apart, i dont mind, thats actualy better in my mind
ill probably try the windshield stuff.
i still want to find those ☺☺☺☺ers and shoot them in the head
jasonty
41
Dec 23, 2018 01:00 PM
coreyedwards7611
Jan 16, 2016 06:38 PM
icentropy
Jul 14, 2015 10:23 AM
coryc85
Jul 6, 2015 04:07 AM
