putting my window in, glue?
im to thepoing where my new diverside window is ready to go in on my 94 4runner, now, the part that bolts to the regulator, how should i secure that to the glass? i want it to work smoothly and outlast the truck.
an good solid solutions? |
still looking for a solution
j-b weld?
What's the FSM say?
butyl tape?
I went to autozone and got some of that glue they use to glue a windshield back onto a vehicle. It's a black almost like silicone stuff. Anyway, I pressed the metal slides on the bottom and had to use a rubber mallet to get them on all the way. Right before I did that I coated all surfaces with a thin layer of that stuff. So far it has done the trick for me.
i would have used clear silicone. or urethane
black silicone will show up..butyl makes an insane mess |
I don't care if it shows up because it's on the channel guides which are on the bottom of the window and never show. Outside of tearing apart your door have you ever seen a channel guide? :hillbill:
Seriously, if I had known what the stuff was I would have used silicone because it's cheaper but that's because I'm a redneck and like to save a dollar. So in that sense, I agree with you, 89macrunner. Whatever you use will probably be okay. Just make sure it's something that will stick to both glass and metal and will have some elastic properties and not just crack everytime there's a little movement and you actually need a material that can be removed (think of your next broken window replacement). Show us some pictures when you're done. I was doing a thread on here and then my wife deleted all the pictures I took the day I put it back together... |
ill post some pics of puttiong it back together.
if it doesnt come apart, i dont mind, thats actualy better in my mind :hillbill: ill probably try the windshield stuff. i still want to find those ☺☺☺☺ers and shoot them in the head |
