What is going on with my engine???
Old Apr 27, 2007 | 11:26 AM
LS1Steve's Avatar
Everything in tune, I get a power loss every now and then....here's the kicker....I can be driving and it feels like i'm not running on all cylinders, I put it in neutral, shut engine off then restart....problem gone for rest of trip.
Old Apr 27, 2007 | 01:56 PM
TNRabbit's Avatar
Possibly a short in your engine wiring harness somewhere? This is a major job to determine where it might be....
Old Apr 27, 2007 | 01:58 PM
AH64ID's Avatar
I would start by making sure no wiring harness is over stretched with the body lift.
Old Apr 27, 2007 | 02:44 PM
LS1Steve's Avatar
the body lift has been on for 16yrs, why would this develop now? and why would turning engine off/on solve a problem with a short?
Old Apr 27, 2007 | 02:53 PM
AH64ID's Avatar
after that long, it may not be an issue.. disregard
Old Apr 27, 2007 | 11:54 PM
^VooDoo^'s Avatar
Actualy it may be an issue, It was fine for awhile but over time the wear and strech is now showing, Check the part of the harness that goes down the firwall over the trans to the O? sensor.
I have kinda the same thing, Mine was the part of the harness that jumps from the body to the engine.
While its running in idle lift up and down on it, I had a bad fusable link there that goes to the injectors, I redid all those links in the harness all the way to the VAFM.
With a body lift you are now putting more stretch at that very spot as that is where the o? sensor harness Y's off.
Old Apr 28, 2007 | 08:34 AM
Shoua's Avatar
Check engine light on?
Old Apr 28, 2007 | 09:40 AM
LS1Steve's Avatar
no check engine light. I really doubt it is a stretched harness
icentropy
Sep 16, 2020 02:47 PM
RaginAsian91
Engine Swaps
Mar 30, 2019 09:17 AM
jasonty
41
Dec 23, 2018 01:00 PM
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
razorman8669
Jul 12, 2015 12:13 PM
