engine cuts out every 1/1/2 months
Old 04-23-2007, 08:40 PM
weakyota91's Avatar
I searched and couldnt find anything. I have a 91 4x4 3.0 and about every month and a halph while accelerating full throttle my engine cuts out and lose power to everything engine wise, tach drops down to 0 and lose all power (not headlights or stereo just motor power) it only lasts a split second and then returns to normal. Dont even have time to react and let off gas. The best way i can describe it is hold engine at about 4 grand in second gear and let off all the way and quickly mash gas pedal back to the wood. It jerks about that bad. Its my daily driver and does it about every month and a half. anyone elses yota replicated this
Old 04-24-2007, 05:55 PM
notanymore's Avatar
just curious when is the last time you replaced your fuel filter?
Old 04-24-2007, 07:09 PM
weakyota91's Avatar
sounds like its a fuel clog somewere huh. changed it in july of 2005 with toyota fuel filter
Old 04-24-2007, 07:20 PM
notanymore's Avatar
im not sure for sure but its my first guess on why. im sure someone else will chime in with some better advice than i can give
Old 04-24-2007, 07:50 PM
Stomis's Avatar
Its ghosts... Get a new truck
Old 04-24-2007, 08:16 PM
KevinInSac's Avatar
I've experienced the same thing in a 90 Oldsmobile, but I blame the fact that it's a GM.
haha, classic.
Old 04-25-2007, 12:19 AM
TNRabbit's Avatar
Is your ECU running on MicroSoft Windows by chance?!?
Old 04-25-2007, 02:12 AM
1994runner's Avatar
check for corroded wires at the coil, igniter and distributor
Old 04-25-2007, 05:44 PM
kddstoy's Avatar
I have the same exact problem on my 91 3.0 5 spd, I have newer (6 months) plugs wires, filters, fuel filter, cap/rotor. Even put in Lucas fuel trearment and kept fingers crossed it would cure I posted about this awhile back but no luck. If you figure anything out PLEASE let me know, I even hoped that it would store a code in the OBD had it scanned and no luck!
Old 04-25-2007, 06:14 PM
4banginRunner's Avatar
that fuel treatment is no joke, good stuff! my buddy had a S10 Blazer that had been running crappy, shudders and sputters, he went and bought a bottle of Lucas at Napa, almost instantiations results! even felt more powerful, all the sputters cleared up within a couple days
Old 02-27-2022, 05:41 AM
Woodmac64's Avatar
Same here! I have a’91 3.0 5 speed 4x4. For me the cutouts have become random. They used to be more frequent. I believe it’s in the ignition system. For me I’ll be cruising down the road and the engine actually quits for a split second. The fact I’m moving and the key is still on restarts the motor. Think of rolling down hill and popping the clutch to start. It’s very quick but startling. I have 329k on this motor and have replaced most standard maintenance items per the FSM. Planning a rebuild soon, so I’ll dig into this issue more then.
Old 02-27-2022, 08:12 AM
Spread5150's Avatar
Is your EGR still in ? Reason I ask is mine was stumbling on start up every so often(once a month or so and I figured it to be the fuel pump). The other day on start up it finally started acting up and it was not going to stop. I would gas it and it died. Plugged the EGR vacuumed and it’s back to normal. I’m in the process of deleting it.
bigjstang
08-25-2021 12:41 AM
sandyota
02-04-2021 11:16 AM
icentropy
09-16-2020 02:47 PM
crashburnoveride
07-10-2015 06:39 AM
Roger Borba II
07-09-2015 05:05 PM
Quick Reply: engine cuts out every 1/1/2 months
