2nd test drive and runs high
Old Jan 17, 2010 | 10:46 AM
86yota321's Avatar
Unhappy 2nd test drive and runs high
Well this is the 2nd test run I've done after putting a different motor in and I need some help figuring this out. I got the motor timed where it should be and it idles just fine. I took it around the neighborhood and while driving I am in 4th gear. In 3rd at 20 mph it sounds alot higher than it should. I don't have a tach at all so I don't know what my rpms are. Driving in 4th at 20-25 the truck sounds normal. What should I start looking for or (this is my first Yota) what's the normal speed ranges for the gears? It's an 86 5 speed, 4x4 with a motor from an 83, so my timing is set at 0.
Old Jan 17, 2010 | 10:52 AM
MuddinRI's Avatar
your speedo right 25 in fourth seems like it would be lugging
Old Jan 17, 2010 | 10:57 AM
camo31_10.50's Avatar
my first gear runs to about 15-20mph
my second gear runs to about 30-35mph
my third gear runs up to 45-50mph
my fourth gear runs up to about 65-70mph
and my 5th runs about from 65mph up to about 105mph....and anything about 75mph is achieved going downhill with a strong tailwind lmao
Old Jan 17, 2010 | 10:58 AM
and these motors love to rev..i usually take mine up to about 3500-4000rpms before i shift..except for 1st and second..or while i'm in town.
Old Jan 17, 2010 | 11:08 AM
86yota321's Avatar
If I slow down to 20 then it does start to lug a bit in 4th but when I get back on the gas it does fine. I thought I might have to do some adjustment on the carb but I'm not exactly sure what I need to adjust. Or if there's something different I need to do.
Old Jan 17, 2010 | 11:10 AM
abeD85flatbed's Avatar
You might want to try advancing the timing to about 12 degrees and see how it runs. Running the engine at 0 degrees is bound to cause issues.
Old Jan 17, 2010 | 11:56 AM
86yota321's Avatar
Problem solved. I get a dumbass award today. Sitting here all pissed off then looked at my 4 wheel drive shifter. It was in neutral. Moved it over to 2hi and guess what? Drove 15-20 in 1st, then 25 in 2nd. Just like what you listed there Camo31. I feel sheepish.
Old Jan 17, 2010 | 01:07 PM
82yota's Avatar
Your skilled on getting the truck to move with the t case in N. I used to put mine in 3rd and N to warm the tranny up in the winter and my truck wouldn't move.
Old Jan 17, 2010 | 01:30 PM
peow130's Avatar
Strange.
My 1st gear goes from 1-about 10,
second 10-20
3rd 20-40
4th 40-60
5th, 60+
You were driving in 2Low? Lolz..
JF9243176
Oct 8, 2017 04:21 AM
JF9243176
Jun 24, 2015 04:53 AM
