Clutch Issues
Old Jan 20, 2010 | 07:46 AM
CitrusTheDragon's Avatar
Unhappy Clutch Issues
I am having major clutch issues. My pedal feels like it only pushes the clutch in about half way when the pedal is on the floor. I have bleed the lines and changed the master(it had a leak) but no help, well it did make the pedal stiffer. I can force it into gear or start it in gear with the clutch down and it won't move(maybe it iches alittle) but I can feather it like it was normal but like I said it only feels like the clutch is halfway in. Has this happen to anyoone else or can anyone help?
Old Jan 20, 2010 | 10:33 AM
TORTIS's Avatar
How did you bleed it?
Did you replace the slave cylinder?
Is your pedal assm cracked and pulling away from the firewall?
Old Jan 20, 2010 | 10:36 AM
881stGenRunner's Avatar
agreed with Tortis, check the pedal assembly and check to see if it has started cracking and "ripping" the metal. If it is doing this, you will not get a full stroke out of the pedal
Old Jan 20, 2010 | 10:42 AM
Pumped up the pedal bleed it clean. Made sure no air. Haven't gotten to the slave yet, u think it might be that it's just not getting enough pressure? I willl look to see if it's crack but I haven't seen or looked yet, I will look.
Old Jan 20, 2010 | 11:08 AM
Ok pedal is fine but the master I bought is now leaking a little. Time for a slave master and clutch kit. I am tired of this crap and want to get it fixed
Old Jan 20, 2010 | 11:09 AM
TORTIS's Avatar
The pedal was held down while someone cracked the bleeder on the slave? Have you looked at the slave and made sure it moved the clutch fork when somebody pressed the pedal.
Did you bench bleed the master cyl?
Old Jan 20, 2010 | 11:11 AM
TORTIS's Avatar
Hopefully it is the master and slave. good luck.
Old Jan 20, 2010 | 11:23 AM
Or u can use a pressure bleeder
Old Jan 20, 2010 | 11:24 AM
Everything looks like it moves right I am think throw out barring
Old Jan 20, 2010 | 11:45 AM
has it always been working properly then all of a sudden go out on you? If it was throwout bearing it sems to me that i would have been making some noise or given you some difficulty getting it into gear for a little while before this happened
Old Jan 20, 2010 | 12:01 PM
I was out playing in the mud then no pedel, I thought if it was the clutch or bearing i would have known a little before hand. I am thinking I will just buy the slave and master rebleed and try again
Old Jan 20, 2010 | 12:06 PM
ahhh i see. mud sucks!!! haha good call on trying to jsut get those and trying again. clutch jobs are not the most fun, but arent too bad on these trucks
Old Jan 20, 2010 | 12:21 PM
I work on a race car and have done alot of quick fix kinda stuff
Old Jan 20, 2010 | 12:52 PM
I got ripped off by a junk yard that will be the last time I do that
Old Jan 20, 2010 | 12:59 PM
what happened man? whatd you try to get from there and they messed up?
Old Jan 20, 2010 | 01:38 PM
I bought a master that leaks for $40, when I could have bought a new master and slave for 40
Old Jan 20, 2010 | 03:21 PM
TORTIS's Avatar
live and learn!
Old Jan 20, 2010 | 04:22 PM
yea well no more yards for me
Old Feb 6, 2010 | 10:32 AM
Ok so i figured out the issuse I was having. 220 later it's the clutch kit and flywheel. After I have put a Master, slave and tons of man hours in
Old Feb 6, 2010 | 12:43 PM
Flash319's Avatar
Broken clutch fingers??
