air fuel ratio
Old Jan 13, 2010 | 11:37 AM
weaselman's Avatar
air fuel ratio
hello all.
what brand of air fuel gauge would you guys recomend?
i was thinking either an autometer or the one you can get at kragen..
i just wanted some opinions on what brands everybody has had the best of luck with.
Old Jan 13, 2010 | 06:11 PM
Erik Beeman's Avatar
Go with the AEM UEGO wideband. I've had buddies run the LC1 and it was not as nice as the AEM, and the Kragen one is trash.
Why do you want one? Do you plan on boosting your motor, or going a standalone?
Old Jan 14, 2010 | 07:45 AM
weaselman's Avatar
Just becuz i would like to know how my truck is running.
And eventually i plan on trying a standalone or the do it urself megasquirt.
That wont be for a while.
Thanks for the input
Old Jan 14, 2010 | 09:04 AM
You're truck will run between 14.6-15.5 on a daily cruise. Or it should. Full throttle it'll drop to low 11's. Or, it should at least.
This is on a good running 22RE.
Old Jan 14, 2010 | 09:22 AM
tgergen's Avatar
I run the PLX Devices SM-AFR + DM-5 AFR Combo. Works wonderful, albeit, a bit on the pricey side. However, it has proven invaluable for tuning, etc.
You just need to weld an O2 bung on your exhaust for the wideband sensor.
http://plxdevices.com/wideband.html
Old Jan 14, 2010 | 09:32 AM
mt_goat's Avatar
I love my LC1, set it up and calibrated it once and its worked perfect for a few years now.
I relocated the emergency flasher switch.
More info on the LC1 stand alone kit: http://www.innovatemotorsports.com/x...ad542d8c62b5da
Old Jan 14, 2010 | 09:39 AM
weaselman's Avatar
Thank you guys a lot. All the information i can get is great.
Thats another reason i want a gauge. Is because i get about 188 to a tank of fuel. Ive heard of people getting 250-300. And sometimes when im cruising i can smell the strong exhaust smill in my truck and im pretty sure its running rich.
Btw my engine just went through a full rebuild and has abt 3500 on it. With cam and bored out... Sooo. It better be a good running 22re. Lol.
Old Jan 14, 2010 | 09:43 AM
Although the PLX is infact a good device, I think it's a bit out of his league for necessity in this project. Hell, the AEM UEGO is a bit pricey to just have to look at. I am currently running the AEM without a standalone right now because I need to see how the motor is running when it sees boost on the stock ECU, for I can't tune or touch it. However, a full standalone has it's own AFR (or Lamba, if that's what you prefer, like I do) gauge in MegaTune.
I absolutely agree with you. I've run the LC1 with a few buddies, and there was no problems. I just personally think the AEM is a little nicer of a unit.
Old Jan 14, 2010 | 10:08 AM
here's my AEM. Interchangeable faceplates, and tunable output settings.
Old Jan 14, 2010 | 10:39 AM
4Crawler's Avatar
I run a Nordskog a/f gauge:
- http://www.4crawler.com/4x4/CheapTri...FuelRatioGauge
Eggslinger
Jun 8, 2019 03:32 PM
Doug4320
Mar 24, 2018 10:11 PM
RatOmeter
Oct 22, 2015 03:17 PM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
smiley52
Jul 11, 2015 05:16 AM
