Newbie with knock sensor wire question
Old Jan 23, 2010 | 03:30 PM
devinscout's Avatar
I have an 89 3vze. The knock sensor wire that goes from the ECM to the pigtail has gotten frayed. Can I just splice the wire and be ok? Do I need to use shielded wire? If I use shielded wire do I need to make sure the shielded part has continuity also? Trying to figure out if I can just splice the inner portion of the wire and not worry about the shielded part. Thanks
Old Jan 24, 2010 | 04:45 AM
devinscout's Avatar
anybody?
Old Jan 24, 2010 | 07:16 AM
betelnut's Avatar
I guess you're trying to avoid pulling the intake plenum and manifold to replace the wire?
https://www.yotatech.com/forums/f2/3...-sensor-49202/
Old Jan 24, 2010 | 10:13 AM
bugs1961's Avatar
Yea, go ahead and do the work properly and replace the pigtail.
Old Jan 24, 2010 | 12:12 PM
Team420's Avatar
He's talking about the wire from the pigtail back....Right?
I did it to mine, rewired it directly to the ecu. I did not use shielded wire... what I did... I wired the actual signal portion of the wire the knk port on the ecm, and ran the shield to the neg batt post. no code 52 anymore.
Old Jan 24, 2010 | 05:03 PM
devinscout's Avatar
Thanks Team420. I was talking about the wire from pigtail to ECM. I recently bought this truck and did an engine rebuild. I replaced the pigtail harness that goes under the manifold, but I did not replace the sensor. I am just trying to rule everything else out before I pull the top part of the motor back off. I`ll have to trace the wire back to the ECM and check continuity. Does anyone know which pin it is on the ECM plug?
sandyota
Feb 4, 2021 11:16 AM
icentropy
Sep 16, 2020 02:47 PM
88yodabasket
Jul 13, 2015 01:32 PM
smiley52
Jul 11, 2015 05:16 AM
garagespace
Jul 9, 2015 08:37 AM
