Intermittant No Start...
Old Jan 19, 2010 | 08:13 AM
qdude79's Avatar
Seems to only happen when heat soaked, but it's NOT overheated by any means. Sometimes, I turn the key, hear the relay click, dash lights dim just a bit (like normal), but it won't turn over. Starter is new as of 30k miles ago. I do notice quite a bit of drawdown on the volt meter, bring the needle down the the exact half mark. I haven't tested to see how much voltage is actually getting to the starter yet, but it's very strange to me. Turn the key a few times, when it does engage the starter, it fires off great. No sluggish turn over. Practically starts with a bump of the starter.
Ideas?
My theories would be wiring, because of the drawdown, possibly the 20+year old ignition switch, and lastly the starter.
Any experiences would be appreciated.
Old Jan 19, 2010 | 08:48 AM
TORTIS's Avatar
I had to install a 4 pole relay to fix my problem. something about the ignition switch not shooting enough juice to engage the starter. pretty simple fix, if that is your problem.
Old Jan 19, 2010 | 08:50 AM
4Crawler's Avatar
Ideas?
See below for some testing tips:
- http://www.4crawler.com/4x4/CheapTri...shtml#EasyTest
And here are some fixes if you find low voltage at the starter solenoid:
- http://www.4crawler.com/4x4/CheapTri...l#OtherOptions
Old Jan 19, 2010 | 09:39 AM
qdude79's Avatar
Thanks, fellas. Sounds like a cheap enough try. I'll do this.
Old Jan 19, 2010 | 10:17 AM
qdude79's Avatar
An aside: I have a 30 amp relay laying around the garage. Any reason not to fab my own "Hot Shot" kit?
Old Jan 19, 2010 | 10:18 AM
4Crawler's Avatar
Sure, give it a shot.
puddlepirate
Jul 30, 2016 06:29 PM
jacked_72
Sep 14, 2015 03:31 PM
Duppie007
Aug 31, 2015 07:04 AM
zeflower
Aug 30, 2015 06:52 AM
landrunner
Aug 5, 2015 09:18 PM
